Introduction: Make a Massironi Shelf
What to do during a rainy weekend? My son and I decided to make a Massironi shelf. Manfredo Massironi was an Italian architect and he was fascinated by visual forms. He designed this shelf. There is a big shelf with 7 planks and a smallar one with 5 planks. We made the one with 5 planks and adjust the original size.
Step 1: This Is What You Need
Computer with CAD program or the pdf files in step 4
Straight planks, we chose pine wood
Paper, pencil
Band saw (jigsaw is also possible)
Sander and sandpaper
Chisel
4 hanging brackets screws
Paint (optional)
Planer
Step 2: Dimentions Step 1
The original Massironi shelf with 5 planks has a diameter of 1676 mm (66 inch) and a depth of 355 mm (14 inch). A shelf of these dimensions takes up much space which is why we decided to make it about 2/3 of the original dimensions, thus a diameter of 1100 mm and a depth of 240 mm. The middle horizontal and vertical plank will follow these dimensions.
Firstly, part of a circle was modeled according to these dimensions (picture 1 and 2).
Step 3: Dimension Step 2
We decided that we wanted about 4 compartments across the shelf. To achieve this the dimensions of the compartments were chosen to be 210x210 mm. Since the wood used was 15 mm the compartments are placed 7.5 mm out from the centre.
The compartments were then extruded from the circle using the Inventor tools extrude and mirror which yielded the part below.
Now there is only one problem left, which is that the part created is a solid part and not several planks, and thus does not directly yield the dimensions to be used. However, this part could be used to measure all dimensions measured for each plank as can be seen in the third picture (The complete dimensions for each plank are shown in the drawings).
Step 4: Drawings
Step 5: Draw Your Template or Not.....
We decided to draw the templates on paper and cut out the joints. But next time I would go to a print shop and print it out in real size. Glue it onto the wood and cut it out. This will made it much more secure than drawing by hand.
Step 6: Plane the Lumber
We planed the lumber to 1.5 cm
Step 7: Draw the Templane on Your Planks
Or if you have printed the templates in the actual size, glue the templates on your planks. We placed the template on the planks and drew it.
Step 8: Cut the Planks
Cut the planks with your band saw or with your jigsaw and sand the planks smooth.
Step 9: Make Half Lap Joints
Cut the joints with a saw and beat out the piece of wood with a chisel.
Step 10: Assemble
Step 11: Assemble and Adjust
Step 12: Apply 4 Hanging Brackets
Apply four hanging brackets and mount to the wall. We choose pine which doesn’t weight much but if you will use oak you may consider a different way to mount your shelf onto the wall.
Step 13: To Paint or Not to Paint
Our plans were to paint the shelf but when it hung on the wall we decided to wait. Pine wood become darker over time, something I don’t like, so I will paint the shelf in a year or so.
After a few Days we decided to paint the wall instead of the shelf.....
Mount the shelf on the wall and place your favourite stuff.
Thanks for reading and if you liked it you may consider to vote J
