Introduction: Make a Mini Golf Course
This is my first instructable and I will show you how to make a small mini golf course. You can make more courses and connect them.
Step 1: Step 1
Lay four jumbo popsicle sticks together and cut another two to fit the length of the four sticks. Then glue the two cut sticks onto the four sticks.
Step 2: Step 2
Now get two jumbo popsicle sticks and glue them on the long sides of your base made in step 1. Then cut one popsicle stick to fit the back of your base. Glue it to the back.
Step 3: Step 3
Now cut a piece of thin, soft material to fit the inside of your base. I am using a thin sheet of eva foam but you can also use cardboard. You then cut a hole where you want the ball to go into.
Step 4: Step 4
Now you need to cut a piece of felt to fit your eva foam/cardboard sheet. Glue them together and then glue them to your base.
Step 5: Step 5
Now you can make the obstacles. BE CREATIVE! I cut two jumbo popsicle sticks and glued them together. I did this twice and glued them to the base in a diagonal position.
Step 6: Step 6
As for the golf club, I got a toothpick and put the thin eva foam on the bottom. The foam was cut into two golf club shapes.
Thanks for watching,
Podem
Podem
