Introduction: Make a Notepad Diary on PC
In this article, there will be a way on how to make your own diary on Notepad. It is very easy to make with just one text & save, it can also update to the date it is after the diary you made last time, your diary will still be saved.
Step 1: Opening Notepad
If you're on Windows and/or PC, open the Notepad app. This can be found via searching on your computer (eg: search tab). If your software has other names (WordPad), use that.
In other words, it is common as Notepad. It should take you to your software's pad look.
Step 2: Writing Your Diary
To do this once you have your notepad opened, type in ".LOG" followed by the photo above, otherwise, your automatic daily diary (ADD) will not work or display the date.
Step 3: Saving to ".txt"
Once you have finished typing, save it as a .txt file, not any .bat or .vbs files. The notepad writing and saving is simple, so you don't need a bat or VBS file.
Step 4: Finishing Notepad Log
After you finished doing everything, go back into your notepad and you should see the time and the date in the format of YYYY-MM-DD.
