Make a Powerful Rechargable Flashlight Out of a Used Battery (earth Day Part II)
Intro: Make a Powerful Rechargable Flashlight Out of a Used Battery (earth Day Part II)
Old lithium ion batteries - many of us have them laying around. And in most cases there is little use for them. Well, until today. In my previous ible and video I showed you how to use them as a powerbank, today I will show you how to turn them into a useful flashlight that lights up your working environment. I also made a project video.
STEP 1: What You Will Need
To create your own helpful tool you will need...
• a used lithium ion battery
• a container that fits your battery and the other components
• some wire
• a lithium ion battery protection and charging board
• a circuit board
• a few female pins
• a small switch
• two 3 Ohm resistors
• 24 white SMD LED's (from an LED-strip)
as well as
• a piece of acrylic
To make your work more efficient some tools might be helpful. I recommend using...
• a hot glue gun
• a soldering ion
• a pair of pliers
• a wire cutter
and of course
• a cutting knife
STEP 2: Make the Battery Pins
STEP 3: Make the LED Panel
When you have all 24 chips, cut your circuit board to the right size and solder the LED's onto it. I will go with a grid of 5X5 LED's with one missing in the bottom row. They are going to be separated into two groups of 12 LED's in parallel. Each of the groups is connected to the power source through a 3 Ohm resistor.
It is a good idea to pre tin the soldering spots before applying the LED's. Carefully push them down while melting the tin underneath from the sides. As I did not have stripped circuit board for this project I used some garden wire to create negative and positive rails and connected the chip's to it.
When you are finished soldering test the panel using a bench power supply or a few AA batteries. When I first attached it to a power source only half of the LED's where working. It turned out that I had caused two short circuits while soldering and three of the LED's were not working at all (I should probably have tested them before). After I replaced the broken chips and repaired everything it finally worked.
STEP 4: Connect the Components and Fit Them Into the Container
I used an old nail container for the housing. Those things are awesome for small electronic projects, that's why I always keep them. Your container should fit your battery as well as the other components. Use a drill to make holes for the switch and the charging port.
When you think that you found a good way to arrange everything, hot glue the parts in place.
STEP 5: Create a Tight Battery Compartment
STEP 6: Insert the Battery and See It in Action
I hope this ible was as helpful to you as this little light is to me and that you found another purpose for your old lithium ion batteries. If you didn't already you might consider reading or watching my previous project and maybe you still want to see my current video.
4 Comments
kja8819a 6 years ago
Do you think it's possible to solder leads directly onto battery instead of using pins?
RANDOM KNOWLEDGE 8 years ago
and I have a question about your schematic,how you calculated the resistance
Becouse I think it is very wrong,you say 5 x in parallel (with 1 of 7 LEDs and 1 of 2 LEDs ( in parallel al the resistors need to bee the same 5"x
In series only 1 resistor (5 LEDs times the voltage devided by current)
In parallel in only 1 row of 5 LEDs ( you need 5 Resistors before each led, of 20Ohm) with 5 volt input
1Rtotal =1*Rtot=1*R1+1*R2'and so on to R5
But you use only 2 resistors before the LEDs
But that's when it is in series, ,I can not see it,and i am not able to come at your 2 times 3 ohm.
Basement Engineering 8 years ago
The battery has a working Voltage of 3,7 to 4,2V while the datasheet for the SMD LED's states that they work best between 3.0 and 3,3V so I have to get rid of around 0,7V.
0,7V/0,24A=2,91Ohm
So I went with a 3Ohm resistor connected in series with the parrelel group of LED's.
You can also go with 24 seperated 35Ohm resistors. I hope I could clear things up a little bit. If there are more questions left do not hesitate to ask.
thanks mate, I Wil look again and recheck,
