Introduction: Make a Solid Wood Photo Frame
Dust off your woodworking tools and make an heirloom photo frame - ideal as a gift!
I'll show you how I made the mitred frame in the photograph, and with that knowledge you should be able to make your own, and even adapt the method to make different styles. All with strong halving joints that will last a lifetime and more.
Vote for it in the Homemade Gifts contest, if you like it :-)
Step 1: Stock Preparation and Rebate
Select some stock of about the thickness you want your frame, planing it flat and with squared edges
Squaring the edges is easy by raising the stock off the bench, and using a hand plane on it's side as shown, adjusting the blade so that it cuts at 90° to the bench
Use a rebate plane to run a rebate deep enough to take the photo', a backing card, and glass if required, on the long edges of one face of the stock (it's much easier to do this while the stock is oversize)
Use a panel gauge (https://www.instructables.com/id/Make-a-Panel-Gauge/), or similar, to mark the width of the frame sections, before ripping them from the stock.
Plane the sawn edges, which will be the outside edge of the frame, so that both lengths of frame stock are exactly the same width
Step 2: Cut Sides to Length
From the frame stock, cut two lengths each for the overall width and height of the frame
For accuracy, mark the second length directly from first, using a marking knife, saw marginally over size, and then use a plane and shooting board to square the ends back to the mark
Step 3: Create the Mitre Halving Joint
Use a mitre square and marking knife to mark in the mitre lines for each corner, on the front face of the frame pieces
Use a marking gauge to gauge a line halfway across the joint's thickness
Saw the mitres through to the gauged line on one half of each joint, and right through on the other half
Saw through the thickness of each half of the joints, to remove the waste and complete the halving joint as shown
For more detail see my joint video: https://youtu.be/MgQC1NY_TaY
Step 4: Assemble
Check the fit of the four joints, and adjust as necessary
Apply adhesive and assemble
Clamp
A large rubber (elastic) band can be stretched around the outside, then four small clamps can hold the halving faces together until cured
Leave to cure
Step 5: Flush All Joints
Use a card scraper to remove any glue squeeze out
Then flush the joints with a finely set hand plane, or abrasive paper on a sanding block
Step 6: Hanging the Frame
A great way to display the frame, is to flush mount it on a wall. This is easily achieved using a keyhole cutting router cutter, which leaves a pocket to hang on a screw head. See my instructable on flush hanging pictures: https://www.instructables.com/id/Hang-a-Painting-Securely-Flush-and-Level/
Step 7: Retaining Contents
To retain the photo, backing card, and glass if used, I drill 2mm holes into the side of the rebate, into which can be pushed short lengths of hardwood cocktail sticks
Gauge the position such that the contents are just held, not squashed
Step 8: Finish
Complete with your chosen finish
I sprayed with Chestnut Finishes water based sealer, and lacquer, sanding in between coats
These can be brushed on, but my Apollo HVLP spray system made light work of it
Install your photo and hang on the wall!
Thanks for reading my Instructable
Merry Christmas!
Mitch
