Introduction: Make a T.A.S.E.R. Out of a Candle Lighter!
make a "taser" on the cheap using a Piezoelectric igniter from a candle lighter.
Materials:
Candle lighter
Project box
Solder
Electrical tape
Epoxy
Hot Glue
Tools:
Drill
Dremel (rotary tool)
Soldering iron
Note: I understand that this isn't a real Taser, or stun gun for that matter. It puts out around 10,000 volts, but with an unreasonably low amperage; too low to harm someone. You can feel it but the pain it inflicts is minor. This project was made just for fun, and isn't meant for self defense.
here are some videos of me messing with my piezoelectric "taser"
Vid 1
Vid 2
Step 1: Dissassemble the Lighter
1: Start by taking the black collar off of the neck of the lighter
Step 2: Crack Her Open.
You can unscrew and pry apart the case, but i just torqued the metal tube against the plastic handle, it opened the lighter right up, without breaking the components.
Step 3: Remove the Plumbing.
Pull the plastic inner-tube out of the metal outer-tube and use your fingers to pry it open. The clear plastic tube pipes the butane to the tip, and the wire connected to to the tip creates a spark with the outer-tube.
Step 4: Remove Butane Tank
Gently pull the tank out, the gas will be released if the metal valve at the top is pulled upward, away from the tank.. Remove plastic triggers while you're at it.
Step 5: Remove the Piezoelectric Igniter
All you need to do is pull the small black rectangle with the wire attached out, it will be easier if you cleared the trigger out.
Step 6: Project Box
Find a decent project box, not made of metal. I used an Icebreaker's sour gun case for mine. Dremel a square for the piezoelectric igniter's button, and drill two holes for electrodes.
Step 7: Electrodes!
For the electrodes I used nails that i cut down to size and dulled with a cutoff wheel. They are about 1.2 cm long. In order to connect the electrodes you'll have to make a second wire from the piezoelectric igniter. on the piezoelectric igniter the brass end is the other electrode, so tape the flat piece of metal that origionally acted as it's contact in the lighter to the brass end.
DO NOT SOLDER!
The Piezoelectric is heat sensitive. I found out the had way that heating it with your soldering iron will break the piezoelectric igniter.
you can, and should, solder the wire and metal strip to separate electrodes.
Tape the contact metal and electrodes. Leave half a centimeter of each electrode untaped.
Step 8: Assemble and Glue.
Insert the electrodes through their respective holes.
Mix up a small amount of epoxy and put all of it on the bottom of the piezoelectric igniter. Place the piezoelectric igniter on the bottom of the project box with enough sticking out of the square hole to be pushed inward and click, creating a spark.
Spread the inner wires as far as possible; the spark will find gaps in your tape job if the wires are too close. Spread hot glue on the innards, holding the electrodes in place and insulating the rest.
Let the glues curate and go shock someone (you can also put the candy back!).
The shock isn't strong enough to incapacitate someone, but it does hurt somewhat; especially if the contacts aren't touching the skin. You can use the "taser" to light the butane from the tank in your dismantled lighter.
51 Comments
Question 4 years ago on Step 5
Where can we buy the material on the right picture ? thank
15 years ago on Introduction
ahhhh very cool. i think me and my friend will do this. (favorited)
Reply 6 years ago
Tried getting piezo out of a bic lighter and failed miserably.
Reply 5 years ago
I'm not sure if you're joking. If you're joking, props. There's not a piezo unit in these types of lighters (they use a flint not an arc). You need a BBQ stick lighter (99 cent stores have them). The 'click' you hear when you press the trigger is the piezo unit which is a self-contained spring and hammer with the PZT crystal.
12 years ago on Introduction
I remember me and my friend once joking about sticking a piezoelectric thing to a capacitor. Now that will hurt! Plus it would be possible for it to called a stun gun for self-defense, but I advise testing it first before actually go on a shocking spree lol.
Reply 12 years ago on Introduction
lol, also try wiring this to a mouse, so when a guy clicks he'll get a surprise...
13 years ago on Introduction
PLEASE this isn't a freakin taser. Taser shoots out a plug and shocks the person s obad hes paralyzed for like 10 seconds. this isn't a taser. It's just a shocker so don't call it taser.
Reply 13 years ago on Introduction
taser doesn't have to shoot two electrodes (prongs)
15 years ago on Step 8
the voltages generated by a piezoelectric lighter aren't enough to offer any sort of protection that a 'tazer' would, and it's irresponsible for you to label it as such. Perhaps "shockbox" or "shock gag" or anything but "tazer" would've been appropriate.
Reply 13 years ago on Step 8
chill out stoooopid, it is not irresponsible of him
Make a T.A.S.E.R. out of a Candle Lighter! Note: I understand that this isn't a real Taser, or stun gun for that matter. Suuuuuuureeee...
ok, that's it. this instructable was the last straw. I am so sick and goddamn tired of people calling anything that can jump a spark, a taser. so help me god, the next person I hear call something a taser, I'm getting a real taser, sticking them in the back of the legs with it, and I will meniacally laugh in the background as they die of heart failure. this is more of a stun gun than anything. a taser, fires two contacts out of the barrels, and stick to the subject. there is another type that uses beams of water, and I barely let that one fly. image 1, is a taser, image 2, is a stun gun.
Could use a water pistol to transfer 300v from the Kodak camera .
Reply 15 years ago on Introduction
"Don't taser me bro! Don't taser me bro!" :) Sorry, I just had to :-)
its dont taze me bro
Reply 14 years ago on Introduction
ACTUALLY it's "Don't tase me, bro!"
hahaha classic
then why does image one say "Police Stungun" ?
yeah
Its a taser, people just have wrong labels, he is correct up there
ask someone with a little knowledge about them.
