Make a Temporary Tattoo Using Tape and Printer
Intro: Make a Temporary Tattoo Using Tape and Printer
This project has three main purposes:
1) Freaking out your mother
2) Costume party/ Cosplay etc
3) Figuring out if you REALLY, REALLY want to get that tattoo you've been thinking about for weeks
I was a smart-ass teen and whenever my mother was angry and/or disappointed with me, I'd cover myself with those temporary tattoos and tell her "it could have been worse". I don't recommend freaking out your mother, but you can try with your partner/spouse..it was rather fun to see my boyfriend hyperventilate once he saw skull "tattoos" on my hands. I'm evil, I know.
Honestly though, those temporary tattoos are great if you are thinking about a real one but can't decide if it will look alright/ can't visualise what it will look like/ can't decide on a placement. I used that method every time I was about to get a tattoo and it helped me a lot.
STEP 1: Choosing Your Design
Sketches, clean lines, black and white designs worked best for me. If you want something more elaborate you will have to experiment. Some sketches had to be adjusted, background made more white, gray lines made more black etc. Don't forget to mirror-flip the images as well.
I can tell you from experience that the quality of this project depends mainly on your printer and the type of ink said printer uses. I used several different INKJET printers and in one case ink was too runny, in other one black ink wasn’t black enough… different printers will produce different results.
You will also have to experiment with printer settings. I printed mine the same way I would a regular document, except I went for a higher resolution. Again, you will have to experiment to see what suits you.
STEP 2: Applying Tape and Printing
Once your design is ready to print, apply tape to either the whole page or just parts of it and print. Be careful not to touch the ink when you remove the page from the printer. Cut the image out, make sure to leave a little on one side so it's easy to handle.
STEP 3: Transferring the Image
I didn't do anything special to prepare the area, except I washed it with regular soap and dried it. If you plan on doing it on a hairy skin, your results might be a little off, but it will still work. You will only get one shot to transfer the image, so do it slowly. If possible, ask for help. Once the design is on your skin, run your palm over it to make sure the whole design transferred and peel the paper off.
Don't touch it until it's dry.
STEP 4: Different Results
STEP 5: Filling With Colour and Sealing the 'tattoo'
You can use colourful markers to add some colour (don't judge me for my awful colouring skills, I didn't have any other markers). Once it's done you can seal it. First step is to apply setting powder, I used whatever I had in my make-up bag, but baby powder or cornstarch would work too. Use a soft brush to remove excess powder. Last step is hair spray. It will make the colours pop and seal the whole thing for up to 36 hours (or your next shower).
Removal is pretty simple, but again it depends on your ink. Soap and water and a little rubbing will work in most cases, use a nail brush or an exfoliating sponge. If that doesn't work use acetone (some inks are a bit stubborn).
Please, make sure you don't do something stupid like get a massive spider 'tattoo' on your neck, then run out of acetone and end up going to work wearing a turtle-neck in the biggest summer heat-wave (happened to a friend).
36 Comments
richaale000 2 years ago
forfsakeplease 3 years ago
parallyze 3 years ago
I just wouldn't recommend any of this. Because depending on the printer the wet ink will leave traces on the transport rollers inside and might mess up your following real prints. Also this might leave ink on sensors inside (for cd printing and other features the printer might have... feed scanner AIOs come to mind...).
This can work reasonably well... but it can have really bad side effects.
shalnachywyt 3 years ago
AndersJ3 3 years ago
tommaso moro 3 years ago
There have been several cases where people have drunk so much water so they have died. No, not drown, they have drunk to much water.
Yes, Chocolate is also toxic, most animals can't handle the amount humans can handle. Humans and rats can handle rather much of it though.
As with most things, it all up to the dosage. Your mileage may vary.
So check the contents of the ink you use.
robertallenpayne 3 years ago
weibbed 3 years ago
https://www.comboink.com/blog/your-printer-cartridge-toxic-or-not/#:~:text=Printer%20Ink%20Toxicity&text=Overall%2C%20printer%20inks%20are%20non,statutory%20rules%20and%20safety%20guidelines.&text=However%2C%20in%20most%20ink%20cartridges,water%2C%20ethylene%20glycol%20and%20alcohol.
Andy_K84 3 years ago
Crayz4life 3 years ago
retiredphnman 3 years ago
It should also be good if the paper is pushed straight through the printer without doing any sharp turns, like in most laser printers. Laser printers also have a dryer, that heat up the paper. That could potentially ruin your Laser printer. And the powder are even potentially more of a risk then the ink to the skin.
So only try it on ink printer.
FrauMartina 3 years ago
Once the image is applied to the skin you have to wait a few minutes for the ink to dry, then sprinkle the powder to set the 'tattoo'.
it uses is considered non-toxic. The ingredients are as follows: water, carbon
black, glycerol, triethylene glycol and triethanol amine. None of which is
harmful to the skin. Prolonged exposure to some of those chemicals can (in some
cases) cause a mild skin irritation, but I don’t recommend you bathe in the ink,
you are using a very small amount of ink for this project.
And yes, EVERYTHING can make people get some problems, as you said. Even sunscreen can generate allergic contact dermantitis. And so do some medicine, have other non wanted effect among the one we do want.
So yes, your warning are good. But as said, we also know we will die some day, that is the only thing we know of. So why not try to have some fun before. And be careful when testing new things.
cougar63701 3 years ago
