Introduction: Make a Two Bladed Wallet Knife From a Hack Saw Blade
Make a Two Bladed Wallet Knife from a Hack Saw Blade
Step 1: You Will Need:
You will need a cheap hacksaw blade. Why cheap? So that the steel is right. High carbon not bi metal.
Bend and brake off a section of blade about the length of a credit card is long.
Step 2: Grind and Shape the Tip Your Blade. No Grinder: Use Aluminum Oxide Sanding Paper.
Grind and shape the tip your blade. No grinder: use aluminum oxide sanding paper.
Step 3: Keep It Cool by Dipping It in Water.
Keep it cool by dipping it in water.
Step 4: Grind the Teeth Off the Cutting Edge.
Grind the teeth off the cutting edge. The trick here is to only just grind off the teeth and no more as this is were the steel is the hardest and will keep the best edge. Note water dripping off blade: Keep the blade cool! or you will take the temper out and it will not keep an edge when you sharpen it.
Step 5: If You Want You Can Sharpen the Blade on a Sharpening Stone.
If you want you can sharpen the blade on a sharpening stone. But mostly it should be very sharp off the grinder.
Step 6: Now Make a Paper Sheath for Your Wallet Knife. Size Your Paper As in Photo.
Now make a paper sheath for your Wallet Knife. Size your paper as in photo.
Step 7: Fold Paper As Shown
Fold paper as shown
Step 8: Continue to Fold:
Continue to fold:
Step 9: Unfold and Then Fold Up Tip to Close End:
Unfold and then fold up tip to close end:
Step 10: Refold:
Refold:
Step 11: And Tape Closed:
and tape closed:
Step 12: Hold Knife As Shown to Use:
Hold knife as shown to use:
