Make a Two Bladed Wallet Knife From a Hack Saw Blade
Intro: Make a Two Bladed Wallet Knife From a Hack Saw Blade
Make a Two Bladed Wallet Knife from a Hack Saw Blade
STEP 1: You Will Need:
You will need a cheap hacksaw blade. Why cheap? So that the steel is right. High carbon not bi metal.
Bend and brake off a section of blade about the length of a credit card is long.
STEP 2: Grind and Shape the Tip Your Blade. No Grinder: Use Aluminum Oxide Sanding Paper.
Grind and shape the tip your blade. No grinder: use aluminum oxide sanding paper.
STEP 3: Keep It Cool by Dipping It in Water.
Keep it cool by dipping it in water.
STEP 4: Grind the Teeth Off the Cutting Edge.
Grind the teeth off the cutting edge. The trick here is to only just grind off the teeth and no more as this is were the steel is the hardest and will keep the best edge. Note water dripping off blade: Keep the blade cool! or you will take the temper out and it will not keep an edge when you sharpen it.
STEP 5: If You Want You Can Sharpen the Blade on a Sharpening Stone.
If you want you can sharpen the blade on a sharpening stone. But mostly it should be very sharp off the grinder.
STEP 6: Now Make a Paper Sheath for Your Wallet Knife. Size Your Paper As in Photo.
Now make a paper sheath for your Wallet Knife. Size your paper as in photo.
STEP 7: Fold Paper As Shown
Fold paper as shown
STEP 8: Continue to Fold:
Continue to fold:
STEP 9: Unfold and Then Fold Up Tip to Close End:
Unfold and then fold up tip to close end:
STEP 10: Refold:
Refold:
STEP 11: And Tape Closed:
and tape closed:
STEP 12: Hold Knife As Shown to Use:
Hold knife as shown to use:
33 Comments
awesomeepiceli 11 years ago
spenfisher12 13 years ago
zigzagchris 14 years ago
www.uniquedaily.com/wp-content/uploads/2009/05/key-shaped-knife.jpg
the bottom one is the exact one i have
im_tux 16 years ago
imakeknives 14 years ago
Kiernan 14 years ago
weaponscollector94 14 years ago
Marble of Doom 14 years ago
asoos1 14 years ago
JamesRPatrick 16 years ago
mazeka.14 15 years ago
ac-dc 15 years ago
JamesRPatrick 15 years ago
Fitwit 16 years ago
ac-dc 15 years ago
imthatguy1125 15 years ago
mowie 15 years ago
Shadowfury 15 years ago
The Rusted Workman 15 years ago
