Make a Wi-Fi Extender
Intro: Make a Wi-Fi Extender
Plagued by unreliable Wi-Fi connectivity? Just found a cheap and relatively easy way to boost a wireless routers signal strength by creating a simple parabolic reflector dish to direct Wi-Fi signals to your intended receivers.
follow me on twitter! http://www.twitter.com/rohanlikhite
Visit my site => http://rohanlikhite.com
STEP 1: Gather Required Materials
STEP 2: Assemble Your Wi-Fi Extender
Print out the template on a sheet of regular paper. You can actually scale the image to a larger sizewhile maintaining the relative dimensionsfor a stronger focus. First, cut out the template pieces, then use a glue stick to affix foil to the front of each piece. Use a knife to make cuts on the indicated slits and bend the reflector to fit the six tabs into the respective holes.
STEP 3: Attach Onto the Router
Slide the booster over the existing antenna of your router and point it in the desired direction.
122 Comments
mrtejas99 3 years ago
Capt Caveman 6 years ago
For this too work at optimum strength, you would need to set the focal point at the correct distance to your reciever, you could try http://www.satsig.net/focal-length-parabolic-dish.htm
tps_wave34 7 years ago
you could prop up a wok-pot lid behind router and point in direction to extend to.
Alexander heron the inventor 7 years ago
Range?can it increase the range till 20% thx bro
StalkerBear 11 years ago
Yesterday had 30kb per second, now it's more than 100 kbps.
And it's with antenna printed on A4 page both parts.
Thanks!!!!
pari191 9 years ago
Hey, can you please explain to me how to do all that work, I am a little confused about the procedure so, please tell me how to do it .
StalkerBear 9 years ago
Wi-fi extender as described here helps you in case where you can focus your antenna in specific direction - then you only put aluminium foil over the printed part, and make 2 holes in it - putting your antenna through.
So, very much depends on what you need
Jacky P 10 years ago
Chollyfish 9 years ago
Sorry, but no. This only works with external antennas.
valentinopaynne 9 years ago
love4pds 12 years ago
Thanks in advance :}
gmacgregor 9 years ago
the sheet metal is most likely grounded to the frame/chassis. But dont get discouraged. Unlike most RVs that are fiberglass and wood, you have been blessed with a HUGE ground plane. This making any antenna that you mount properly, work much better.
steveoo6 12 years ago
machetesgirl 10 years ago
LaughSing 12 years ago
You just saved me a trip to Radio Shack, buying a cable splitter, and moving my cable modem and router. This gave the router the boost it needed to compensate for my new camera's body being beefier than the old one, interfering with the Eye-Fi card.
Maybe it ain't pretty, but it's off in the den. The other choice was putting the cable modem and router in the living room, which would be even uglier. So, yeah, it's beautiful. :)
amylove 12 years ago
cncnorman 15 years ago
sn00ze 13 years ago
unwrittenrainbow 14 years ago
johnson_steve 15 years ago
