Make a Wing Bolt From a Plastic Bottle
Intro: Make a Wing Bolt From a Plastic Bottle
More than once I needed a wing bolt, but I did not have one.
In this Instructable, I show you a trick how you can make a wing bolt from a bolt and a plastic bottle.
STEP 1:
I cut off the bottle neck
STEP 2:
I put the bolt in the vice and heated up the bottleneck with a heat-gun.
If you don't have a heat-gun, you can use an oven or a candle.
STEP 3:
I used my hands and pliers to shape the wings.
STEP 4:
Then I cut off the excess plastic
STEP 5:
That's it! Our wing bolt is ready.
You might assume that the plastic will break, but actually it's very strong.
I could no break it with my hands.
Apart from making the wing nut, you can use this method to undo nuts and bolts in emergency situations.
37 Comments
Microbe 6 years ago
DakotaLally 6 years ago
Good points, but if in a true emergency, work with the tools you have available to get the job done.
ShakeTheFuture 6 years ago
Lovetra 6 years ago
In this Instructable I used a bottle from a sparkling water..... it's just like a like a coca-cola bottle.
It works very well because it's very hard.
I tried to use a cap from a juice carton, but it was too soft.
Lovetra 6 years ago
That is a great idea! I often read things like this but forget about it when the time comes, a practice run to cement it to memory would certainly help.
JimG50 6 years ago
NathanKing 6 years ago
alhaxxor 6 years ago
Lovetra 6 years ago
I do it all the time. Making journeys to the store and spending 1h of my time only to buy small item that I did not have in stock.
That teaches me to stock up on things I might use, but you you never know what you'll need :)
АлександрБ62 6 years ago
мне пригодится ....полезно...!!!
bill2009 6 years ago
This is great - thanks.
carl5blum 6 years ago
Hello:
Nice idea!
You could put a fender washer under the head and hold it there with a nut. Then when you formed the wings they wouldn't need to be trimmed below the bolt head.
Thanks, Carl.
