Make a Wooden Game Cube
Intro: Make a Wooden Game Cube
Great for playing chess, cards, Monopoly with Grandma, etc... It's not quite the same as Nintendo's GameCube, but it will cost you a lot less, and if you wanted to, you could even have dinner for two on it.
STEP 1: Gather Materials
As seen in the picture, I used a pair of metal snips, an electric drill, small-holed metal squares (for the corners), a box of screws, and large wooden panels for the sides.
STEP 2: Make Pyramids
Draw an X on the squares. Then cut out one of the triangles using the snips.
These metal pieces will be sharp after you cut them. I recommend using something to dull the edges, like a grinder. A grinder will also make some fun sparks. Dan demonstrates grinding and sparking in the picture.
I used the edge of a table to bend the pyramids into shape, a hammer may be needed if your metal is too thick to bend with your hand.
Check out the video to see some sparks in the dark.
STEP 3: Build the Box
Before building the box, we added supports using small pieces of 2x4. Basically, one goes on each end of the square. Then the sides all screw into them, instead of each other. If you look at the picture below where Dan is pointing at the support, just imagine him pushing that 2x4 to the edge, screwing it down. Then doing the same on each edge. The other panels then screw into the 2x4s.
STEP 4: Box + Pyramids
Dan will point you through this: You'll need some screws. Dan shows you one in the picture. Screw the pyramids onto the box corners. Voila! You have a game cube.
STEP 5: Play a Game
Find an opponent of similar skill and intelligence to challenge. Needless to say, I lost this match, but the war will wage on.
11 Comments
GASSYPOOTS 12 years ago
Director13 14 years ago
ibayibay1 15 years ago
REA 15 years ago
slimguy379 15 years ago
coolmatt 16 years ago
http://www.shopsmith.com/ownersite/proj_articles/chess/
JakeTobak 17 years ago
ARVash 17 years ago
Hawaii00000 16 years ago
ich bin ein pyro 17 years ago
Punkguyta 17 years ago
