Introduction: Make a Humidifier for Your Home or Greenhouse... That Works!
The time is near. Dry season is on its way, and you’re beginning to scramble. Trying desperately to figure out what you’re going to do to keep your humidity levels where they need to be. Then you find out that you could end up spending over $1000 dollars on a humidifier big enough to handle your entire home or greenhouse!
I know, it's crazy expensive! Well, there IS a better way, a much better way. For under $300 you can easily make your own unit that blows away the store bought models. The House of Hydro’s commercial foggers can nebulize up to 32 gallons of water a day! They are the perfect tool for building your own humidifier. All you need is a container and a fan to get it done. It’s that simple.
Making a fully automated humidifier for the home, greenhouse, or grow room is super easy! You will only need the following items:
  1. Any size House of Hydro Mist Maker kit. We Stock 1 through 12 Disc Foggers!
  2. Waterproof Fan Kit  (120mm is the best option anything over 2'x4'x6' H)
  3. Humidistat  (Optional)
  4. Mist Output Controller  (Optional)
  5. UV Sterilizing Light  (Optional)
  6. Auto Fill Float to fill your reservoir (Optional)
  7. 4" or 5" Fan/Duct Adapter Optional)
  8. Jig Saw, Razor Knife or 4.75" hole saw for the 120mm, and 3" Hole saw for the 80mm Fan
  9. Philips Head Screwdriver and four 2" outdoor wood screws, or 6-32x2" machined bolts with nuts
  10. Silicone Caulk (Optional)
  11. Saran Wrap or cooking spray (Optional)
  12. Small GFI Power strip
  13. Appropriately sized water Reservoir. Use a 27-gallon Tuff Tote for 6 Disc Units and larger. No less than a 5 5-gallon bucket for 1 to 5 Disc Units. The water level must be kept as full as possible to avoid overheating.
How to build your basic or fully automated DIY cool mist humidifier:
  1. Prepare the fogger. Place the silver transducer into the black float.
  2. Assemble The fogger by plugging the silver transducer into the black transformer and tightening down the locking ring if there's one available. Your fogger is now ready to create mist. Just drop it in water to activate!
  3. Next, we will mark and cut 2 or 3 similar holes in the lid of the water reservoir. Two are for output, and one is for your waterproof fan input. If you choose to have one output hole, it needs to be larger than the fan if you want to run the fan at full speed.
  4. The hole for the fan will be marked using the fan opening as a template. We then cut one or two holes for the output side. These holes need to be about twice the size (In Total) of the fan hole to prevent any back pressure on the fan. It's not the end of the world though. If you do have backpressure, you can turn down the fan speed.
  5. To easily add a round duct to your fan, or your output holes, you can purchase our 120mm adapter piece.
  6. Using the screwdriver and deck screws or stainless nut's and bolts, mount your fan in place.
  7.  (Gaskets are Optional) After cutting the holes you can make gaskets for your lid to prevent fog from escaping. Fan Gasket: lay a fat bead of silicon on your lid around the hole for your fan. Then place Saran Wrap over the silicon to prevent the fan from sticking permanently. Press the fan gently into its final mounting position, and let the silicon dry. Once dry, remove the fan and Saran Wrap leaving a formed gasket on your lid. Lid Gasket: turn the lid over and lay a VERY GENEROUS bead of silicon around the lid where it snaps onto the container. Lay Saran Wrap over the silicon to prevent permanent adhesion (or use cooking spray) and put the lid back on the container. Let the silicon dry and remove the Saran Wrap leaving behind a gasket. Depending on the type of tub, this is not necessary unless you are in an area where a few drops of water on the floor are an issue.
  8. Cut a small notch in the water reservoirs edge to allow room for the cord to pass through. You can also use a grommet to run the cord if you want a clean finished look.
  9. To easily add a 5" duct to your intake, or exit side, you can use this duct adapter.
  10. Drop the mist maker into the water, and place the lid on top. You now have a basic humidifier that will run 100% when plugged in (Note: 8 hours on, 1 hour off is the max run time)
  11. You can manage the output with a Humidistat (fully automated controller), Mist Output Controller, or a basic timer from Walmart
To make a fully automated humidifier, read on...
  1. The next step is to add your Autofill Mini Float to the reservoir. This will allow for an external water feed to keep your water reservoir full. To do this, you will drill a hole just a hair larger than the floats threads, at least 3/4 of the way up the wall of your water reservoir. Check the cap for water flow direction and mount the float. Using a 1/2" water supply line, you can then hook up to an external source. NOTE: If in an area that you can not afford a spillover, it is recommended you put an overflow drain on the water reservoir in case of a valve failure. These are extremely rare but can happen if you have very hard water that can build up on the valve's internals.
  2. Now you're ready to set up all the products together. Plug the humidistat into a GFI Outlet (like you have in your bathrooms) Anytime you have water and electricity, you should use GFI when available.
  3. To run your fan and mist maker together, plug them both into a small GFI power strip, and then plug the strip into the humidistat. This way they operate simultaneously when the humidity drops too low.
  4. Now you set the mist maker into the container and place the lid on top. Set your humidistats parameters, and you're ready to go!
  5. Mount the Humidistat sensor in a central area, and make sure to J Hook the sensor so any water build-up does not fun onto the sensor, but will drip off the cord instead.
If you have any questions at all about how to build your own humidifier using Mist makers, please feel free to contact us at John@thehouseofhydro.com. We're always more than happy to help!
  1. Waterproof Fan Kit  (120mm is the best option anything over 2'x4'x6' H)
  2. Humidistat  (Optional)
  3. Mist Output Controller  (Optional)
  4. UV Sterilizing Light  (Optional)
  5. Auto Fill Float to fill your reservoir (Optional)
  6. 4" or 5" Fan/Duct Adapter Optional)
  7. Jig Saw, Razor Knife or 4.75" hole saw for the 120mm, and 3" Hole saw for the 80mm Fan
  8. Philips Head Screwdriver and four 2" outdoor wood screws, or 6-32x2" machined bolts with nuts
  9. Silicone Caulk (Optional)
  10. Saran Wrap or cooking spray (Optional)
  11. Small GFI Power strip
  12. Appropriately sized water Reservoir. Use a 27-gallon Tuff Tote for 6 Disc Units and larger. No less than a 5 5-gallon bucket for 1 to 5 Disc Units. The water level must be kept as full as possible to avoid overheating.
Step 1: Step 1: Drill (3) 3.5” Holes in the Lid of a Tuff Tote Storage Tote. Two Holes on One End, and One on the Other
Hole sizes are optional, but we recommend using at least a 4 inch output hose for full efficiency
Step 2: The Hole That Is by Itself Is Your Fans Mounting Hole. Mount the Fan Face Down With the Air Blowing Into the Tote. Use the Caulk to Seal the Fan to the Lid, and Use the Bolts, or Screws, to Hold the Fan Securely in Place.
Step 3: Step 3: Drop Your New Fogger Inside the Storage Tote After Filling Half Way With Clean Water.
Step 4: Step 4: Close the Lid and Plug in Your New Humidifier.
Step 5: Step 5: Spend Your $700 Savings on Something That’s Worth Your Hard Earned Money!
