Introduction: Make a Remote Controlled Camera From a Cellphone!
Want to know what your cat is doing while at work? Send a text message to your newly made surveillance-cellphone and receive pictures and videos seconds later. Sounds like a dream? Not any more!
This video explains how it works:
Step 1: Parts and Tools You Need
A brave camera-cellphone (including SIM-card). I'm currently using a Sony Ericsson T630.
A microcontroller (I use a Picaxe 18x)
Solenoid relays
Photoresistor (LDR)
LED
A few resistors might come in handy
Wires
Soldering iron
Solder, cutters, tape etc.
Oh, and another working cellphone.
Solenoid relays
Photoresistor (LDR)
LED
Wires
Soldering iron
Step 2: Making It
The idea is to replace your fingers with the relays and your brain with a microcontroller. Depending on how complex your phone is, i.e. number of different keys to press in order to send a picture, choose your microcontroller accordingly.
My setup uses four outputs (four different keys on the phone) and one input on the microcontroller. It allows me to send a SMS text message (or call) to my hacked phone and it then cycles through the code, clicking its way through the menus, taking photos and returning them to me.
I was optimistic about the joystick and quickly soldered up the wires. The joystick has up, down, left, right and center as possible connections. I had to crack open another joystick to figure out the connections. "Making a "right" or "left" requires many different pins to be connected in a certain manner and order, e.g;
""Right;""
First; yellow + black + blue + brown
then; purple + orange
I experimented and found that I could rationalize by always keeping some wires connected. This worked but made the joystick on the phone immobilized. For "Right" I ended up using two relays:
on relay 2
on relay 1
pause
off relay 1
off relay 2
Relay no.1 is the top left button on the key pad ("Select" and "capture"). Relay no.3 is the top right button on the key pad ( "more" and "send").
""Right;""
on relay 2
on relay 1
pause
off relay 1
off relay 2
Step 3: The Code
This is actually my first project involving a microcontroller. I recently acquired the Picaxe Experimenter board (and USB Programming Cable ) and I would highly recommend it for those interested in learning about micros.
Let it be said; I'm a terrible coder and there are thousands of ways to do this better. The code is ugly but but it works and can be snatched below.
The red standby-Led helps in confirming that the program is running:
standby:
high 5
pause 100
low 5
pause 300
goto main
When a text or call is received a LED connected to the speaker output shines onto the LDR (light dependent resistor). The value is then read:
readadc 2,b0
if b0 < 90 then standby
if b0 > 90 then run
The start of the "run" command:
run:
wait 2
high 3
pause 100
low 3
pause 400
wait 6
high 1
pause 100
low 1
pause 300
high 2
high 1
pause 100
low 1
low 2
pause 300
standby:
high 5
pause 100
low 5
pause 300
goto main
readadc 2,b0
if b0 > 90 then run
run:
wait 2
high 3
pause 100
low 3
pause 400
wait 6
high 1
pause 100
low 1
pause 300
high 2
high 1
pause 100
low 1
low 2
pause 300
Step 4: Relays
Why do I use relays? Well, I tried using transistors but my phone was so sensitive to stray voltages that I quickly opted for relays.
The relays are actually great for this project because they give you a visual and audible confirmation at each step as the code is running. Another great advantage is the fact that you can interact directly by just tapping them. And besides, they look amazing don't they?
Step 5: The Result
The surveillance-phone works like a charm and there's no end to the possibilities of this device. I plan to monitor my dorm while away for the holidays.
Please don't forget to rate me and be sure to visit my other Instructables!
Have fun!
Have fun!
