Make a Vintage Display Cabinet or Island
Intro: Make a Vintage Display Cabinet or Island
Home-Dzine has been inundated with requests to show you how to make this vintage
distressed cabinet, so here it is. With it glass panel doors, this
vintage distressed cabinet is not only useful for storage and display in
a home, it also makes the perfect kitchen island in a rustic or cottage
kitchen. Made using 16mm SupaWood / MDF, you will find everything
you need for this project at your local hardware store.
YOU WILL NEED:
See Cutting List
5 x 60mm screws
24 glass panes (measure once panels cut out - make the glass slightly smaller)
8 decorative butt hinges + small screws
4 double-roller door catches + small screws
8 shelf pins
8 vintage brass or pewter knobs + screws
Matt paint if distressing and finishing with antique wax / clear sealer
Sheen paint if you are not distressing
1000-grit sandpaper
TOOLS:
Drill/Driver + assorted bits
Countersink bit
Dremel Trio + TR675 bit set
Jigsaw + clean-cut blade
Orbital sander + 120- and 240-grit sanding pads
Bosch PFS spray system - or paintbrush and foam roller
Tape measure and pencil
IF YOU NEED TO CONVERT TO IMPERIAL MEASUREMENT: http://www.simetric.co.uk/feet_to_metres.php
YOU WILL NEED:
See Cutting List
5 x 60mm screws
8 shelf pins
1000-grit sandpaper
TOOLS:
Countersink bit
STEP 1: Assemble Centre Section
As shown in the diagram - start off by assembling the centre section.
Note that all holes are pre-drilled using a 3mm wood bit at 50mm from
the top, side of bottom edges.
1. Along the 504mm length, measure in 226mm from both sides and draw a line on the top and bottom of the top shelf [F]. Using this line as a guide, attach the top shelf to the shelf support [G] via pre-drilled and countersunk holes through the top shelf.
2. On both sides [C] measure up 176mm and 192mm and draw a line on both sides. Use this as a guide for mounting the shelves [E], first on one side as shown...
3. And then attaching the other side [C].
4. Completed centre section.
STEP 2: Add Base and Top to Centre Section
5. With countersunk pilot holes pre-drilled along the front edge of the base [D], and pilot holes pre-drilled in the base front and back [K], attach these sections together.
6. Measure in and mark at 449mm in from both short ends on both sides of the base, draw a line, and use this as a guide for securing the base [D] to the centre section.
7. Centre section with base added.
8. Add the top [A] using the same method.
STEP 3: Attach Side Panels
Cut out side panels for fitting glass
Before attaching the side panels cut out the openings with a jigsaw. See Step 12.
9. Attach the side panels [B] to the frame by aligning the top edge.
10. Completed frame with side panels.
11. Add the front, back [H] and side aprons [J] to the base of the frame, as per diagram ADD APRON.
STEP 4: Assemble Drawers
Assemble the drawers
Drill pilot holes and countersink to attach the front and back to the sides.
Test fit the drawers and sand if necessary before painting the drawer fronts.
Insert shelves.
Drill holes in the sides for shelf pins for mounting the shelves [L].
Paint the shelves separately.
Insert shelves.
STEP 5: Sand and Paint
Painting
Before painting you need to sand down all the edges and make sure that everything is nice and flush. Any uneven edges can be sanded with 120-grit and then smoothed with 240-grit.
Wipe clean to remove all traces of dust.
I prefer to use a Bosch PFS spray system for painting all my furniture projects, but you can use a paintbrush and foam roller if you don't have a spray system - it just takes longer.
Apply two coats of paint, allowing each coat to dry before applying the next coat.
Sand with 1000-grit sandpaper before applying another two coats of paint and sanding again.
At this stage you can decide whether to leave the unit as is, or to apply a distressed finish to the edges. You would do this using 120-grit sandpaper, either by hand or with a Dremel MultiMax. After sanding, you can apply two coats of clear sealer or antique wax.
STEP 6: Rout Panels for Doors
Cutting out door panels for fitting glass
Before mounting the doors [M], measure and draw a line 50mm in from the front, back, top and bottom edges. Each opening measures 160 x 330mm. Cut out the openings with a jigsaw.
12. Rout the front of the cut panels with a beading bit, and the back of the cut panels with a rabbet bit. The beading bit provides a decorative finish on the front, while the rabbet bit cuts out a rebate for fitting the glass panels.
Adding the glass panels
After sanding and painting the doors, place the glass inside the rebated section at the back of each door.
Place a strip of masking tape around the edge of the glass approximately 2mm in from the edge.
Secure the glass using acrylic sealer and remove the masking tape before the sealer has time to set.
STEP 7: Finishing Off
Finishing off
13. Add hinges to all the doors and fit the doors to the frame.
14. Attach double-roller catches - mounted at the top of each door.
15 & 16. Add handles or knobs to the doors and drawers. - See more at: http://www.home-dzine.co.za/diy/diy-glass-cabinet...
STEP 8: Completed Vintage Display Cabinet or Island
Shown here, vintage display cabinet with doors open to show hinge mountings.
This particular unit has not been distressed, but you can add light, medium or heavy distressing to suit your particular style and taste.
Visit www.Home-Dzine.co.za for more information on this project and other DIY furniture projects.
5 Comments
crazywoman38 9 years ago
I can't find any overall dimensions? Need to see if I have room or if it needs to be adjusted. Thanks!
dezine 9 years ago
The top is 500mmW x 1500mmL so that should give you an indication of the space required. The finished height is 900mmH.
dezine 10 years ago
PAR stands for planed all around - so it's already smooth pine that you are working with and only need to be sanded.
temper 10 years ago
Nice, great to see MDF being used instead of Walnut, Cherry, Oak etc. that are only affordably available in North America.
One question though in relation to the linked site, what does PAR stand for - I have heard of DAR (dressed all round) but not PAR - could it be planed all round?
temper 10 years ago
..and that relates to plywood too...
