Introduction: Make an Adjustable Tablet Stand
Last year I got tablet fever.
I schemed of ways to rationalize buying a tablet and came up with a perfectly plausible reason to buy one. (right honey?) I have a giant pile of recipes that I have printed off the internet as well as other recipes and notes that I've collected over the past 25 years of cooking. It's a drag shuffling through piles of papers looking for the recipe you need. ( Yes, I've organized them several times but they get pulled out and I can't seem to keep up). Going digital with the recipes made sense but a laptop is just too vulnerable and takes up too much counter space in the kitchen. A tablet would be perfect. A convenient place to organize and access all my cooking stuff in a device with a small foot print.
I was in Bed Bath and Beyond shopping for Christmas stuff and just happened to notice that they had book readers. Long story short I got one. It was a Pandigital Novel which I converted to an android tablet.
After trying to prop the tablet up on the counter with apples and other useless items I realized that I was going to need a stand for this thing. I wanted something minimal and adjustable that I could sit on the counter above the mess.
Step 1: Stuff You're Gonna Need....
Materials
Plastic cutting board, 1/2" thick- I had it on hand. A nice piece of wood would work too.
Plastic snap together coolant hose- Get the Male NPT kit from Enco for $8.
A base- I had a nice metal lab equipment base. A piece of 3/4" thick wood would do fine here as well.
A metal clothes hanger or similar gauge wire.
Felt
Spray glue & super glue
Tape
Tools
A saw to cut the wood or plastic
Two pairs of pliers
Wire cutters
Scisors
Drill & bits
1/4" pipe tap
Metal file
Felt
Tape
Tools
Two pairs of pliers
Wire cutters
Scisors
Drill & bits
1/4" pipe tap
Metal file
Step 2: Support Plate
First cut the plastic/wood for the tablet support plate to the width of the tablet and 2/3 of its height. Drill a 7/16" hole in the support plate. Center it between the left and right sides and about 2/3 of the height of the plate. The hole should be at the center of the back of the tablet when the bottom edge of the tablet and the support plate are lined up. Tap the hole for 1/4" pipe threads. If you don't have a tap you could just drill the hole over-sized and glue the neck in.
Step 3: The Neck
Take the plastic snap together hose and parts kit and assemble the neck for the stand. Mine has six of the ball and sockets, a 1/4" pipe threaded male end on the top and a 3/8" nozzle on the bottom. The plastic parts can be really hard to snap together. I dip them in hot (just off boiling) water to soften them up a bit if they are giving me trouble.
Step 4: The Base
The 3/8"" nozzle fit perfectly in the base that I had. My base even had a convenient thumb screw. Cut a base that is wide enough to support your tablet. Mine is 4.5" in dia. Drill a 3/8"" hole in the center for the neck. Test fit the support plate, neck and base then take the support plate off the neck.
Step 5: Drill Holes
Drill a hole just wide enough to accommodate the clothes hanger wire on the right and left sides of the support plate. Center it in the thickness of the material and 5/8" from the top edge. Go in 1/2" deep. Put two holes in the bottom of the plate. Centered in the thickness and 1/2" deep again but 5/8" from either side.
Step 6: Felt Facing
You can see that the surface of my plastic cutting board was gross looking. I wanted to cover it and provide a scratch free surface for the tablet to rest on. Lay the support plate on the felt and trace it. Cut the felt to fit and use some spray glue to attach it to the top of the support plate. Put something heavy on it while it dries.
Step 7: Side Guides
In order to hold the tablet to the stand we need to make some wire guides. Cut a 4" piece of clothes hanger and file one end smooth. Mark the wire at 1/4" from the smooth end.
Hold the wire with the two pliers. One on either side of the mark and bend it 90 degrees.
Lay the tablet on the support plate and put the bent end of the wire on top of the tablet next to the right hand hole at the top of the support plate. (I have a picture that explains this in the next step.) Mark the wire where you will need to bend it to go into the hole.
Bend it to fit and trim the bottom off to fit in the hole. You should have a squared off "C" shape. Make another one for the left side.
Step 8: Bottom Guide
The bottom guide is a similar concept but a little trickier to describe. Take a longer piece of wire and bend it at 90 degrees 4" from the end. Measure the distance between the holes in the bottom of the support plate and make the second bend at the same distance. You will have a large "C" again.
Measure and mark 1/4" in from the left hand side of the "C" on the top and bottom. Bend the wire 90 degrees so that the left hand side now sits perpendicular to the table.
Rest the wire on the tablet and support plate again.
Mark it at the bottom holes and bend each end so that it will turn in and fit in the holes. Trim the ends to fit in the holes.
Step 9: Glueing
Put all the wire pieces in the support plate and test fit the tablet. it will be a little tricky with the wire not glued in yet. You are looking for the wire guides to hold the tablet securely but not scratch or drag on the tablet. You can adjust the wire with the pliers until you have a fit that you like. Glue the wires into the holes with super glue. Use tape to hold everything in place as it is drying.
