Introduction: Make an Inspirational Shadow Box Collage
About: My artistic life keeps growing and evolving and I love being a part of it as it does. I went from painting little pictures for my son's nursery to mixed media artist with a craft tutorial blog, artsykarma.com.…
I came across a kit called “Inspire Poster.” It appeared to have little matchbox quotes and dioramas. It inspired me to try making one myself without getting the kit.
Step 1: Get and Empty Matchboxes
Step 1
Grab a couple of packs of matchboxes and separate the box and cover. You'll want around 20 boxes altogether.
I put all the matches and the cover with the strike strip in a ziplock in case I might need some matches some other time.
Step 2: Arrange Matchboxes
Step 2
Arrange the matchboxes into a collage shape. Leave about half right side up and half upside down. This is to give you an idea of how many vertical and/or horizontal quotes you'll need.
At this point, I took a picture, so I could remember how to do it later.
Step 3: Find and Print Quote Images
Step 3
Go online and pick out some quote art on Google images or Pinterest. Put the quotes in a program where you can resize them. I used the app Goodnotes, but you could also use Word. Print the quotes out.
I decided to make my shadow box about creativity and art. You could pick a different theme or whatever floats your boat.
Step 4: Choose Quotes
Decide where to put the quotes
Step 5: Pick Colors
Decide what color to paint the box you'll glue them to.
For example, in the picture below, I chose to paint the box for that quote black, so it would match the quote.
However, it would be good to pick a color scheme of 5 or 6 colors only to use if you can, to make the whole piece consistent. As you can see, I chose basic rainbow colors.
You will also need to paint the insides and sides of the boxes that will go inward.
Step 6: Attach Quotes
Once the paint is dry, use a glue stick to attach the quote to the colored box.
Glue all the quotes onto their already chosen colored box. Keep in mind how many vertical or horizontal quotes you need when you put the shadow box art back together.
Put your boxes with quotes to the side for now as you embellish the rest.
Step 7: Embellish the Boxes
Since this step will depend on the supplies you have on hand, I'm just going to show you what I did. You'll probably have to get creative with the embellishments you have.
Since the theme of my shadow box collage was art and creativity, I found some scrapbook stickers that had that same theme:
Step 8: Use Alphabet Stamps
Step 9: Use Other Embellishments
Step 10: Piece Collage Together
Using the picture you took earlier, piece your collage together, at first without gluing it.
This way you get an idea of how it's supposed to go. You can make any changes if you need to.
Step 11: Attach Boxes Together
Pick up an edge box and one next to it. Use a double-sided tape roller to attach them together where they're supposed to.
Pinch down on the boxes, so it gets a good hold
Step 12: Attach Supports to the Back
Once you've pieced and attached them together with the adhesive tape, gently flip the whole thing over.
Glop glue onto a popsicle stick and arrange as many as you need, to attach all the boxes.
Try to make sure you don't get any popsicle sticks to show on the other side.
Step 13: Attach String to Hang
Now, to make it be able to hang on your wall, thread some embroidery string through a large needle. Tie the end with a big knot.
Going through a box from the backside, poke your needle through till hits the big knot.
Now go to the other side of the collage and poke it through a box on that end and tie it off.
Step 14: All Done
Now flip your shadow box collage over and hang it on the wall!!
