Introduction: Make an Assistant for Your Computer in 5 Minutes
Heard of the new iPhone 4S with Siri? In under an hour I made one for windows in VBS. Now I can open youtube just by saying "youtube OK"
or search google by saying "google OK" Get prepared for making your own new form of using your computer.
You will need
-Windows Vista and up Machine (if you want voice activation. if not windows 98 or higher)
-5 minutes
-Microphone (If you want voice activation)
You will need
-5 minutes
Step 1: Setup Speech Recognition
If you want to use speech recognition with this follow these instructions. If not, skip to step two.
Go to
Control Panel>Ease Of Access>Speech Recognition>Train your computer to better understand you
Follow the directions that it gives you and read the text aloud.
Go to
Step 2: Open Notepad
Press Winkey + R
Type in "notepad"
Hit enter
Type in "notepad"
Hit enter
Step 3: Copy This Script Into Notepad (voice Activation)
Set Sapi = Wscript.CreateObject("SAPI.SpVoice")
set wshshell = wscript.CreateObject("wscript.shell")
dim Input
wshshell.run "%windir%\Speech\Common\sapisvr.exe -SpeechUX"
Sapi.speak "Please speak, or type, what you want to open?"
Input=inputbox ("Please speak, or type, what you want to open.")
if Input = "youtube" OR Input = "Youtube"then
Sapi.speak "Opening youtube"
wshshell.run "www.youtube.com"
else
if Input = "instructables" OR Input = "Instructables" then
Sapi.speak "Opening instructables"
wshshell.run "www.instructables.com"
else
if Input = "google" OR Input = "Google" then
Sapi.speak "Opening google"
wshshell.run "www.google.com"
else
if Input = "command prompt" OR Input = "Command prompt" then
Sapi.speak "Opening command prompt"
wshshell.run "cmd"
else
if Input = "calculator" OR Input = "Calculator" then
Sapi.speak "Opening calculator"
wshshell.run "calc"
else
if Input = "notepad" OR Input = "Notepad" then
Sapi.speak "Opening notepad"
wshshell.run "notepad"
else
if Input = "" then
else
Sapi.speak "I don't recognize your input, Please try something else"
end if
end if
end if
end if
end if
end if
end if
dim Input
else
else
else
wshshell.run "cmd"
else
wshshell.run "calc"
else
else
if Input = "" then
else
end if
end if
end if
end if
end if
end if
end if
Step 4: Copy This Script Into Notepad (no Voice Activation)
dim Input
Sapi.speak "Please type, what you want to open?"
Input=inputbox ("Please type, what you want to open.")
else
else
else
wshshell.run "cmd"
else
wshshell.run "calc"
else
else
if Input = "" then
else
end if
end if
end if
end if
end if
end if
end if
dim Input
else
else
else
wshshell.run "cmd"
else
wshshell.run "calc"
else
else
if Input = "" then
else
end if
end if
end if
end if
end if
end if
end if
Step 5: Test the Script
Now save the script as assistant.vbs
Once the file has been saved run it, and it should tell you its ready for a command.
Say one of the options and then say OK.
It should open that option.
Step 6: Personalization
You can replace a chunk of code in here to open something else fairly easy. Lets start with one of the chunks, lets say, calculator.
else
wshshell.run "calc"
Say I want this to open bing.com
You have to change 4 parts.
else
if Input = "HERE" OR Input = "HERE" then
Sapi.speak "HERE"
wshshell.run "HERE"
The first one must be all lowercase. bing
The second one has a capital first letter Bing
The third is sapi speaking so something like Opening Bing
The fourth is the target www.bing.com
So it would look like this
else
if Input = "bing" OR Input = "Bing" then
Sapi.speak "Opening bing"
wshshell.run "www.bing.com"
!! Make sure everything has quotation marks around it or else it will be considered a variable not a text string!!
In case you were wondering why there was a capital and lowercase bing, it was so the program would recognize two common ways bing is written (with or without capitalization).
else
wshshell.run "calc"
else
Sapi.speak "HERE"
wshshell.run "HERE"
else
Step 7: Save and Test Again
Now that you have set the program to your liking, you can save it and run again. Test anything you set yourself to make sure it works. If it works move on. If it doesn't check your spelling or retry.
Step 8: Yay!
Now that you have a shortcut program you can open youtube with two words. Get to google by speaking. This is very useful and fun to show to your friends. I don't want to see any comments saying "you could just use run" because you obviously didn't read through, since run doesn't automaticaly run sapi or speak after you open it. Anyways, thanks for reading.
Super_Nerd
Super_Nerd
