Make an IPod Speaker From a Hallmark Music Card
Intro: Make an IPod Speaker From a Hallmark Music Card
Ever get one of those cards for your birthday that plays music when you open it? Don't throw it away! With a little help from Tony the Tiger, you can use it as a speaker for your iPod.
STEP 1: Required Materials
Hallmark Music Card
Old headphones
One empty cereal box from a Kellogg's Cereal Variety Pack - I used Frosted Flakes, but you can choose your favorite cereal. It will not impact the outcome of this project. ;-)
Glue Gun
Electrical tape
Utility knife
Not required, but helpful: Soldering iron
Old headphones
Glue Gun
Electrical tape
Utility knife
STEP 2: Remove Speaker From Card
Use a utility knife to cut along the top and bottom edge of the card to expose the speaker.
Cut the speaker wire at the base of the circuit board first and then gently remove the speaker from the card. If you don't cut the speaker wire first you could end up ripping the wire from the base of the speaker and then you'd really need a soldering iron.
The speaker is fixed to the card with a small circular piece of double sided tape, so it shouldn't be too difficult to remove. Avoid the urge here to use your utility knife to "cut away" the speaker - you could accidentally cut right into the speaker itself.
Finally, strip about a quarter inch of insulation from the wires.
Side note: In case you're wondering, the Hallmark card is powered by a CR2032 3V Lithium Battery. This is the key ingredient for making an LED Throwie and is the power house for a bunch of other Instructables. The battery isn't necessary for this Instructable, but holding on to it could prove to be handy down the road. ;-)
STEP 3: Prep Headphones
Cut headphone wires at the base of each headphone (L & R). You'll only need one of the two lines so pick the one you want to use and cut the other where they converge mid-way down the length of the chord.
Next, strip the wires. You may notice some fiber-like material interlaced with the leads themselves. Strip this stuff out with your utility knife or you will not be able to get a solid connection from your headphones to the speaker (thanks to Richard at my local Radio Shack on that one). Alternatively, you can use a soldering iron to burn this stuff away. I found this method much easier and a bit more effective.
STEP 4: Connect
Connect headphone wires to speaker wires. I'm not sure if it matters which ends you connect, but make sure you're getting sound before you seal the deal, so to speak.
Once you've connected your leads (again, soldering here is a good idea, but not necessary) insulate and tidy up the exposed connections with some electrical tape.
STEP 5: Prep Cereal Box
You'll want to cut a whole slightly smaller than the full diameter of the speaker. Remember the nice beveled edge Hallmark utilized to fix it to the card with double sided tape? We'll want to do the same thing here. A 1.25" diameter hole should be perfect. There's a dashed line that runs through the middle of the box that will help center you up before you cut.
You'll also want to cut a small hole towards the bottom rear of the box to feed the headphone jack through. Feeding the wire through the back/bottom of the box not only makes it look nice, but also weights the box so that it doesn't fall forward on its face when you stand it up on end.
STEP 6: Secure Speaker, Seal Box and Rock
Run a small amount of glue along the beveled edge of the speaker and quickly attach it inside the box. Hold it to give the glue a chance to dry. Secure it by adding some spots of glue along the top and bottom edges of the speaker where it meets the box. Try not to glob it on so that you don't add more weight. I ended up using way more than I should have, but it didn't make the box unstable.
Finally, glue back together the top and bottom of the box as it was originally sealed, connect an iPod and kick out the jams.
318 Comments
ewilhelm 15 years ago
link22 10 years ago
Dang! My dad put both wires from the headphones into both wires from the speakers and I didn't work. DO NOT DO THIS! It is unfixable,
Adambowker98 11 years ago
link22 10 years ago
As loud as the card played the audio
link22 10 years ago
Can I use a different heat source to burn away the fiber stuff?
droski21 11 years ago
4lifenerdfighter 12 years ago
Noahslater16 12 years ago
mg9990 12 years ago
I made this video, based off of this instructable :) hope it helps anyyone. feel free to ask me questions
nickiek 13 years ago
mg9990 12 years ago
Frank Lampard 13 12 years ago
Nirgal38 15 years ago
PKTraceur 15 years ago
Laminarin 15 years ago
A cheap (about 60 cents US) amp is a LM386. You can wire according to page 5 of the datasheet (http://cache.national.com/ds/LM/LM386.pdf)
pin
6 battery +
4 battery -
3 ipod out jack tip
2 ipod out jack collar
5 small capacitor and speaker in series (other end of speaker is
ground or neg on bat)
It runs on 4-12 volts and puts out ~0.3 watts.
BBFNN 12 years ago
Nirgal38 12 years ago
8 ohms + 8 ohms + 8 ohms + 8 ohms = 4 x 8 ohms = 32 ohms.
wotot2 15 years ago
