Introduction: Make Your Own Chocolate Lego Mold!
This could be done with virtually any toy or figurine but the more detailed it is the harder it may be to get it to come out perfectly.
Supplies:
- Instamorph Moldable Plastic
- Legos®
- Glass dish for heating
- Sharp Kitchen Knife (Adult Supervision Required!!)
- Rolling Pin or flat surface to use as a press
- Cooking Spray
Step 1: Heat Your Instamorph
Pour your instamorph in a glass dish and cover with water.
Heat in the microwave until instamorph becomes clear and the beads stick together.
Step 2: Prepare Mold
Once instamorph is heated carefully remove from the dish and put on a flat surface sprayed with cooking spray.
Use a rolling pin or the bottom of a pan, cover with cooking spray, and then press the instamorph until it is the thickness you desire for your mold.
Step 3: Trim Excess
Using a sharp knife cut off the excess plastic so you have a square mold.
Submerge your plastic in the hot water for another minute.
Step 4: Create Mold
Gather Legos® and remove your plastic mold from the water.
Quickly press legos® into the mold in the desired order.
Let Cool.
Step 5: Remove Legos®
Once the mold is cooled remove the legos® (they should pop out fairly easily) and voila, you have a lego® mold for jello or chocolate.
