Make Your Own Kraft Paper Tubes
Intro: Make Your Own Kraft Paper Tubes
I've enjoyed making homemade model rockets ever since I was a kid. I make almost every part of my rockets from scratch, including the paper tubes for the rocket bodies.
I often need to make homemade paper tubes for other projects as well, so I thought this deserved a proper write-up. Hopefully someone will find this information useful.
Note that these tubes will not be adequate for any firework-type application, if that's what you're looking for. There are plenty of tutorials online for making convolute (or parallel, non-spiral wound) paper tubes.
STEP 1: Materials
First, you will need some kraft paper. I bought a 36-inch wide roll at Home Depot a few years ago, and it will probably last me a few more. Sometimes I use thin painter's masking paper, but only as a final layer. You can get this at home improvement stores as well.
You will also need some water-soluble glue. I use Titebond (which is a basic woodworking glue), but you could use Elmer's or something similar.
Other basics you will need are a long ruler, cutting mat with rotary cutter or x-acto blade, paint brush, masking tape, and rags.
Most importantly, you will also need some kind of existing tube to use as a form. I generally use pieces of PVC or old cardboard tubes (like mailing tubes, carpet roll tubes, etc.), but I have also used steel pipe and other random cylindrical objects.
For whatever item you use as a form, it is crucial that it is true (meaning without any warps or bends). You can quickly test objects out by placing them on a flat surface and rolling them back and forth. If you see any light coming through along the bottom edge at any point, it means the tube is not true and you should use something else.
STEP 2: Cut Paper Strips
The paper tubes are made by gluing up multiple layers of kraft paper onto the form. For smaller diameter tubes (2" and under), I usually use three or four layers, which produces a fairly lightweight, but reasonably solid tube. For larger diameter tubes (over 2") I use four or five layers. This has been sufficient for most applications I have needed.
For whatever diameter tube you are making, you need to cut strips of kraft paper that are appropriately sized for wrapping around the form. Too narrow, and your spirals will be really close together resulting in a shorter finished tube. Too wide, and you wont be able to wrap it very easily. Some quick trial and error will show you what width strip will work best for whatever size form you are using.
For the tube I am making in the photos here, I am using an 18" piece of 1 1/4" PVC pipe for the form. I have cut three strips of kraft paper that are 3" wide, and 36" long. This size strip works well for this size form.
STEP 3: Wrap the First Layer
Do not use any glue on this step! You want this to slide off of the form when you're finished.
Wrap the first strip around the form in a spiral fashion, without overlapping any of the seams. Use a small piece of masking tape to fasten the kraft paper to the form at both ends.
Make especially sure that the paper is wrapped snugly and that all seams are butted together without any gaps or overlapping.
STEP 4: Glue on Additional Layers
Now you will glue on additional layers of kraft paper.
The glue will need to be watered down. I mix one part water into about four parts glue. (If it helps at all, I've noticed that correctly watered-down glue has almost the exact consistency of store-bought eggnog, straight from the container.)
Brush a layer of glue onto a strip of kraft paper. There shouldn't be any puddles, and the entire strip should be completely and consistently covered.
Begin wrapping it onto the tube over the first layer of paper, making sure to cover the seam on the first layer. The seams on each additional layer should not fall directly over the seam from the layer beneath it. This is very important.
For each layer, you want to make sure the seams are butted nicely against each other, and that there is no overlapping. The glue will allow you a few seconds to reposition the paper as you begin to wrap it, but you do have to work quickly. Once you have the paper positioned well for the first wrap around the tube, you can continue wrapping and pressing the paper into place until you reach the other end of the tube.
As you wrap on a strip of glue-saturated paper, you will feel that it can be stretched and pulled a little. You want to put each layer on snugly without any bubbles or wrinkles, but if you pull it too tightly or with inconsistent pressure, the finished tube will warp as it dries. I've made my share of warped, useless tubes.
In between layers, you will want to use a wet rag to wipe up any glue off of your work surface.
Once each layer is in place, roll the tube on the table back and forth with your hands with substantial pressure to work the layers together to create a good bond.
STEP 5: Trim the Ends
The ends of the tube will need to be trimmed before you can remove the paper tube from the form.
The best way I've found to do this is to wrap a regular sheet of paper tightly around the tube and use the edge as a guide to help you get a nice straight cut. Use an x-acto blade to cut through the layers of kraft paper, and peel off the trimmed end. There will be a little bit of glue on the form which you will want to wipe off.
STEP 6: Let It Dry
Carefully remove the paper tube from the form. I like to stand mine up while they dry so there's no pressure on them horizontally.
I've tried speeding up the drying time by placing tubes in front of space heaters, but it has always led to warped tubes. So I recommend just letting them dry by themselves.
Once dry, I often paint on a layer of glue to seal up the paper, followed by a light sanding with 220 grit sandpaper.
To cut them to various lengths I prefer to use my chop saw (power miter saw). The edges need to be sanded lightly after each cut, but it is quick and accurate.
STEP 7: Making Telescoping Paper Tube Sleeves
I often need to make telescoping tubes that slide nicely in and out of each other. For this, I have made special forms that produce tubes just a hair bigger than what come off of my plain tube forms.
A sleeve-making form needs to be built up by gluing layers of kraft paper directly a plain form. I glue onto the new form however many number of layers I use to make tubes on the original form, plus one. This generally means four layers, and this has worked out well to produce tubes just bigger than the ones that come off of the original forms.
Sometimes I already have an existing tube that I'm going to use for something, like a mailing tube, and I need to just make a sleeve that fits over it. In this case, I'll cut off a section of the tube to create a form, and glue on one layer of kraft paper. This new form will produce tubes that work as sleeves for the original tube.
There is a bit of shrinkage that occurs, so don't fret if tubes and sleeves don't fit at first. Let them dry fully, and if things still don't fit, you can either add another layer to the form and try again, or add an additional layer to the smaller tube so it fits better in the sleeve.
STEP 8: Rocket Motor Mount Tubes
To help make these small paper tubes, I made a jig from a used rocket motor, a dowel and some duct tape. Photos 2 - 4 show how it works. If you have any questions about any of this, please ask.
That's it. Thanks for looking!
53 Comments
carter.boland 3 years ago
Alfredschrader 4 years ago
Never underestimate the power of these cardboard tubes. Good job !
Prfesser 6 years ago
Hi, about 20 years ago I wrote a pamphlet on making spiral-wound paper tubes, very similar to your methods. It's currently sold by Apogee Components:
https://www.apogeerockets.com/Rocket_Books_Videos/...
Like qdogg, I found that gummed kraft packing tape works best. It's often made from virgin kraft which is stronger than the recycled stuff. It doesn't wrinkle significantly (a BIG plus, let me tell you!). Tubes of almost any length can be made---cutting a strip of kraft paper more than 3-4 ft long with parallel edges is something of a chore. And it's quite cheap---$7 for a 600 foot roll of 3" wide, which works nicely for tubes over 1.5" diameter.
http://www.dickblick.com/products/kraft-paper-tape...
2" wide and even 1.5" wide tapes can be found on eBay and Walmart:
https://www.walmart.com/ip/Pacon-Pre-Gummed-Self-A...
A few hints from my own experience:
--A layer of waxed paper, with ends scotch-taped to the mandrel, and/or a little talcum powder (talc, not cornstarch) makes it easier to get the tube off the mandrel. Careful: tape doesn't stick well to wax paper and it's easy to wrinkle the wax paper while winding.
--As you pointed out, the tube shrinks when drying. For near-perfect sized tubes, use a double layer of waxed paper and talcum on the mandrel. Slide the finished tube off, a little more talc on the mandrel, then slide it back on to dry. Usually it will shrink to a tight but still-can-get-it-off fit. If it is still too tight, three layers of waxed paper.
--Tubes much over 2' long may warp a bit after they're made. Winding layers in opposite directions helps some, though it's tedious.
--For you rocketry nuts, 1/2" EMT conduit is just about right for 18 mm (BT-20) tubes. 3/4" EMT is a bit small for 24 mm (BT50) but can be built up with a few layers of tape. 1" conduit is about right for 29 mm tubes.
seamster 6 years ago
Very good info, thank you!
My methods were all just made up through trial and error, so it's nice to see that others have gone down this same road with better results. The use of kraft tape is a brilliant idea - if I ever make tubes like this again, I'll definitely try your suggestions. Thanks again :)
qdogg 7 years ago
How about using old school gummed back paper packing tape. I have 2 big rolls I got at a shipping supply place & all you do is moisten the back and wrap around the form. Some of this tape is reinforced with fiberglass threads. Also, you don't need to "precisely calculate the pre-cut lengths for each layer" in spiral winding as stated in a previous post unless you love math--just make them longer than you need & trim when dry.
seamster 7 years ago
That might be a great method - I'd be curious how it would work out. Give it a shot!
RushFan 7 years ago
Very nice. I like how you build your rocket parts from scratch, rather that relying on store-bought, mass produced items. So much more satisfaction!
Thank you. It's incredibly satisfying, that's for sure! :)
ZekeF 7 years ago
Hey, very cool. That nosecone looks fantastic.
I finally got myself a lathe a while back, after wanting one for many years. I'll have to follow your lead and turn a nosecone for my next rocket! :)
ZekeF 7 years ago
Very nice, it looks straight and true!
It is a little bit of a fussy process, but with a little practice you can make some great custom tubes. Glad to hear it worked for you! :)
JGDean 7 years ago
Back when I made model rockets, I used to make most of my own engine mounts and tube adapters (by the methods you describe) because the local hobby stores wanted too much for my budget (very low). I probably still have some 25-year-old parts kicking around.
Very cool! It's a great hobby. I find myself returning to it every few years and making a few rockets. My kids are now old enough that they can actually make some themselves. Pretty fun stuff.
Thanks for the comment! Just saw your clamps instructable. That is a really good write up, I quite enjoyed it.
Laral 7 years ago
This is a very precise tutorial. Nice job. I am wondering if you have tried the 'dry glue' method as outlined in How To Make Your Own Body Tubes - Apogee Rockets.
They use a hot iron on paper that has dried glue on it, in oder to avoid warping. I am thinking of trying it using a heat gun. They are making convolute-wound tubes but it should work for spiral-wound as well.
There is also The Mathematics of Spiral Wound Body Tubes - Apogee Rockets, which shows how to precisely calculate the pre-cut lengths of each layer for spiral-winding.
Thank you!
I hadn't ever seen these instructions from the apogee site, but they look really useful. I just kind of made my methods up, so some of the things I did might not be the best approach in reality.
I appreciate you sharing the links, and I'll have to take some time to read through those more thoroughly. I haven't made a rocket tube for several years... too many projects!!
StephenA94 7 years ago
As a model rocket enthusiast, and rocket scientist, I am always looking for ways to make my rockets without having to spend hundreds of dollars on specific company tubes. This tutorial is quite revealing. I do have a few questions though. When you put a lay-up on your form, do you crisscross the layers, or put them on in the same direction? Aerospace applications tend to use a crisscross pattern for strength. Also, about how long does a form take to dry? Finally, how do you cut your motor centering rings?
Hi!
Criss-crossing layers never worked for me, as it tended to cause the earlier layer to "unravel," basically. Going the same direction keeps the layers tight.
I think the forms took about a day or so to dry. But it depends on so many factors (size, amount of glue used, local temperature and humidity, etc.).
For motor centering rings, it depends on what material I used. If I used cardboard or paper based products, I usually just use an x-acto blade. If I used thin plywood, I use a scroll saw.
Hope that helps! :)
It does. I tried your process and it worked. I finally read the remainder of the comments, and followed the advice of Dream Dragon; I want the motor mounts to be strong. Currently though the kraft paper I have found was quite thin. Rolling up took 4 sheets, 18"x8" along the 8" edge for an 18" roll-up on a 1/2" form. So I ended up with about 42 layers of thin paper and glue. It's about 100F in my garage, but humidity is around 50%. So I expect the roll-up to take about 3-4 days. That said, using an x-acto knife to cut 1/4" rings, how do you do that through 42 layers of glue and fibers (paper)? The Apogee folks do this for thinner thickness tubes, but a thickness of about 1/8" is not simple.
Your suggestion to tape down the ends worked very well, better than I thought. On a different note, did you ever consider 3D printing of the centering rings?
You lost me on the motor mounts question. Are you cutting through the side wall of the tube (is that what is 42 layers)? Or are you talking about cutting centering rings? Maybe upload a photo of what you're working, and I can respond more specifically.
But depending on what you're trying to cut, if you're trying to cut through that much paper I'd treat it like wood and cut it with power tools, say, like a dremel or a scroll saw.
I've never considered 3D printing, but if you have access that could be a good option.
