Introduction: Make Your Own LED Bar
In this project I will show you how I build my own LED Bar around my 15x10 RGB LED Matrix. It has a top shelf which is made of acrylic glass and it lights up with the push of a button. With the help of a WS2812B LED strip I can change the color of the top shelf and also use animations to light it up. Now I will present you all the steps which are involved if you want to build something similar.
Step 1: Watch the Videos!
It would be the best to watch both video parts of this project one after the other to get a good idea of how I made this project. And as additional support I will now present you a small parts list with example sellers, schematic and code for the electronics.
Step 2: Order Your Parts!
You will need these parts to build the electronics for the lighting system with the WS2812B (affiliate links). You can find the other parts (wood, paint, screws,....) in your local hardware store.
Ebay:
WS2812B LED Strip:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Hook up wire:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 5V 3A Power Supply:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Attiny85:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 8 Pin IC Socket:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10k Resistor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 2 Pin Terminal:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Tactile Push Button:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10k Potentiometer:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x PCB (copper lines):http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Power Switch:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Push Button:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
WS2812B LED Strip:http://amzn.to/136D2MW
Hook up wire:http://amzn.to/1zohKWS
1x 5V 3A Power Supply:http://amzn.to/1Adjjq5
1x Attiny85:http://amzn.to/1GoUHyr
1x 8 Pin IC Socket:http://amzn.to/1Adjvpk
1x 10k Resistor:http://amzn.to/1Adkcis
2x 2 Pin Terminal:http://amzn.to/1wacxlE
1x Tactile Push Button:http://amzn.to/1GI7ydi
1x 10k Potentiometer:http://amzn.to/13qJa3M
1x PCB (copper lines):http://amzn.to/13qJijE
1x Power Switch:http://amzn.to/1wxW6zx
1x Push Button:http://amzn.to/1xlBrAs
Aliexpress:
WS2812B LED Strip: https://s.click.aliexpress.com/e/_d7UgTnE
Hook up wire: https://s.click.aliexpress.com/e/_dSjlxDI
1x 5V 3A Power Supply: https://s.click.aliexpress.com/e/_dXaot6s
1x Attiny85: https://s.click.aliexpress.com/e/_d6jWL8U
1x 8 Pin IC Socket: https://s.click.aliexpress.com/e/_dUOyoO4
1x 10k Resistor: https://s.click.aliexpress.com/e/_dTPpXjt
2x 2 Pin Terminal: https://s.click.aliexpress.com/e/_dYbstfZ
1x Tactile Push Button: https://s.click.aliexpress.com/e/_dXIIMcP
1x 10k Potentiometer: https://s.click.aliexpress.com/e/_dX83GAF
1x PCB (copper lines): https://s.click.aliexpress.com/e/_dY2kgvt
1x Power Switch: https://s.click.aliexpress.com/e/_d9dxPD5
Step 3: Build the Circuit!
Now it is time to build the circuit. Here you can take a look at my schematic to build this with your own board design or you can just remake my board by using the two board layout diagrams.
Step 4: Program the Attiny85!
If you do not know how to program the Attiny85 then you can take a look at my other video:
You can also find the arduino code here. Make sure that "ledbarledstrip.ino" is inside a folder with the same name and the code file "functions" is also inside this folder. Then you just need to open "ledbarledstrip.ino".
Step 5: Success!
And that was everything you need to know to build your own LED Bar. I hope it inspired you to build something similar.
Feel free to check out my Youtube channel for more awesome projects:
https://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information.
