Introduction: Make Your Own Magnetic Stirrer 2S
After doing the first and the second version of magnetic stirrer, I thought that could be a good idea to make a 2s version.
I redesign it to make it simpler to use. Also it is more stable that 2nd version.
You can use it however you want. You can blend your tea or coffee, and because it's also portable you can take it wherever you go.
It is lighter and the only thing you need to make it works is a 9V battery.
You can also use it in your chemistry lab.
I hope you'll like it!
Step 1: Materials
Most of my materials are recycled so don't forget to keep your old devices to salvage useful parts.
- 3x2 cm perf-board
- a LM317 Terminal Adjustable Regulator (recycled)
- wire (preferably colored)
- 1 red LED (preferably super bright)
- a 5KΩ potentiometer
- 1KΩ resistors (recycled)
- a 240Ω resistor(recycled)
- a 10µF polarized capacitor (recycled)
- a 0.1(100n)µF capacitor (recycled)
- a panel mount 2.1mm DC barrel jack
- a CD-ROM(DVD-ROM/RW) geared motor (recycled)
- a 9V battery clip
- a 9V battery
- a 12V DC power supply with 2.1 mm jack
- a 1N4007 diode
- a CD case for 20 CDs (recycled)
- a black paint spray
- varnish
- a round piece of steel
- a round piece of glass(bigger than the case's diameter) (recycled)
- shrink tube
- 40 cm of plastic hose (0.5-0.7 cm thick, preferably colored)(recycled)
- solder wire
- 4 x 3mm screws(recycled)
- 4 x screw nuts(for 3 mm screw)(recycled)
- 1 x 4mm screw
- 1 x 4mm screw nut
- a small cooling radiator(you can get it from the processor of a video card)
- easy slide pads
- 2 x round classic magnets(recycled)
- 5 x 3 mm thick round magnets(5 mm diameter)(recycled)
- superglue
Tools needed:
- Cutting tools
- A drill
- 3x2 cm perf-board
- a 9V battery clip
- a 9V battery
- a 1N4007 diode
- varnish
- shrink tube
- solder wire
- 1 x 4mm screw
- 1 x 4mm screw nut
- easy slide pads
- superglue
Tools needed:
- Cutting tools
- A drill
Step 2: Paint the Case
First thing you have to do is to make the holes for the DC jack, the LED and the potentiometer. You're free to make wherever you want, but firstly I recommend you to make a plan of magnetic stirrer in your mind.
Next clean the CD case and be sure that there aren't no more fats or dirt.
Design and paint the case. I choose the black color because it looks great.
After that, you may varnish your case in order not to "lose" the paint.
Step 3: Cut the Bottom of CD Case
In order to fit the geared motor in the case, I have to cut a piece of the middle "tower" from the inside of the CD case.
After that, put the support of the geared motor on the middle "tower". If the 4 mm screw is too big, cut it.
Step 4: Make the Circuit
Firstly, you may clean your perfboard by washing it and rubbing it with a sponge.
After that, you shouldn't touch the perfboard in order not to let your fingerprints on the perfboard.
Then you're free to start soldering the stable parts (the chip, the capacitors,..).
Mount the potentiometer, the LED and the DC barrel jack.
Next solder the mobile parts, I mean the wires.
Step 5: Mount the Magnets
Mount both classic magnets on the round steel sheet.
Glue them with superglue in order not to "fly" when you're using the magnetic stirrer.
Mount the top of the CD case. The magnetic stirrer is almost done.
Step 6: Make the Chemicals Protector for the Case
Take the round piece of glass, align it on the case and make some notes.
After that, take three transparent easy slide pads and stick they on the glass so as it will be fixed, will not anymore be able to move.
Take the bigger tube, make a straight cut on it, fix it on the glass's edge, then stick the ends of it (the tube) with superglue.
This thing will protect your stirrer against chemicals's action.
Step 7: Make Your Own Stirring Bar
Make a bar of the six little magnets.
Varnish it in order not to rust.
Now you can use it as a stirring bar.
Step 8: That's All.
Below you have the prove that the magnetic stirrer 2s is working.
