Introduction: Make Your Own Pom Poms!
If you don’t absolutely love pom poms or haven’t ever considered making them yourself, perhaps we can sway you after this week’s DIY. We adore pom poms and were beyond excited to discover the Clover Pom Pom Maker, which allows you to crank out pom poms of all sizes and 10 times faster than the conventional method.
You will need a few skeins of yarn, a Clover Pom Pom Maker and a pair of scissors.
(All links are for my Amazon Affiliate, if you are going to purchase your supply's anyway please do it through my links. Thanks for the support and God bless!)
Step 1:
The Clover Pom Pom Maker separates the process into two halves; you’ll start the first half of the pom pom by cutting about 7 yards of yarn. A time saving trick is to double it up twice, so you are working with 4 strands at one time. Because time is money, right? Wrap the yarn from one edge of the arch to the other, making sure you have the entire area covered. Close the arch and repeat the same steps on the other side. Once both arches are covered, insert your scissors into the middle ridge and cut along the entire circle. Tie off your pom pom by slipping a piece of yarn along the middle, pull it into a tight knot, open your arch and pull your pom pom maker apart. Trim up your pom pom if necessary but leave the long piece of yarn you used to tie it together, as you’ll need that to attach your pom poms to….well, just about anything.
Step 2:
We must warn you that this process is quite addicting and you really can’t stop at just one. The possibilities are endless as you can make anything you want! Have fun!
