Introduction: Make Your Own Soda - - Cheap!
So I like carbonated beverages. Soda, Beer (especially beer), Champagne, whatever bubbly.
So I found this Lindsay Press deal about how to make your own soda.
http://www.lindsaybks.com/prod/index.html
There are three options
1. Spend a lot of money and buy a commercial soda fountain or it's parts. Expect to pay at least $200 even on ebay for a carbonator unit (a pump and a chamber probably without regulators)
2. Ferment. Take sugar water, add yeast and wait. This is definitely the lowest cost solution, but I don't like to wait.
3. Follow the instructions that follow
4. OK There is a fourth option: Buy the premade stuff (but hey, this is "instructables" right? We like to Do it ourselves.
So Stuff you will need: CO2 canister - If you can't afford one (or don't drink enough beer to have a kegerator) then troll the streets. Restaurants often leave these out in back to be exchanged with new ones. Choose a large chain restaurant to steal from. No, don't steal. CO2 is useful for other projects. Buy a cylinder. They last a long time (essentially forever) You will need to buy a regulator. $40. buy a new one.
Step 1: Gather Materials
I chose this method since I had a CO2 cylinder, regulators, hoses, fittings and whatnot already in my possession. If you don't have stuff like that, then fear not. The total cost will still be less than that of the in-line carbonator devices.
So gather your materials:
*Plastic 2-liter bottles - they must have that ring below the neck
- There are 2 neck sizes , and I have built this for the smaller, more common size.
- Metal plate - about one square foot should be plenty. Stainless steel is probably ideal. I used plain old mild steel, and aluminum could work if it's thick enough not to bend easily.
- Pipe Fittings - I'm using 1/4" pipe fittings
- short nipple (i used brass)
- valve (also brass)
- quick disconnect air fittings (2 male, 2 female) and some air hose
- teflon tape
- CO2 cylinder ( you can get a very small one which will last a good long time at a beer brewing supply store, or a welding supply store)
- CO2 regulators (also available at brewing supply store or welding supply store)
- wing nuts and carriage bolts (1/4" are good) about 2 inches long.
- some kind of gasket material. -- silicon aquarium sealant is probably best, but I have used bike innertube successfully
Step 2: Metalwork - Make the Plates
First measure and cut two plates of your metal.
Mine are about 1.5 inches by 3 inches.
Notice the image below. You are planning to make the bottom plate with a slot in it to fit around the neck of the plastic bottle below the "shoulder", and the bolts will run up through both plates to secure the top plate against the opening in the top of the neck. The top plate will have the hole for the CO2 to be delivered into the container full of cold water.
Before you get started, put the container filled with water into the refrigerator.
Then cut your plates.
measure for the u-shaped cut out.
The neck of the plastic bottles is almost exactly one inch, so my plate is cut out to about 1 1/8 inch, which is a bit large, but still works.
So then cut the u-shape however you can. I used a cutting torch to do mine. You can use a hole-saw perhaps to start then a hack saw to finish, or perhaps you use a jig-saw or recip-saw. Whatever you have.
Next you need to drill the holes for the clamping bolts. Stack the plates, and drill both plates at once. This way your holes will be sure to line up even if they are not perfectly spaced.
Last, drill and tap the hole for your CO2 fittings. Mine are 1/4" Pipe.
Step 3: Assemble Fittings
You now are ready to assemble the fittings.
The CO2 will enter the assembly through a quick-release air coupling. These are commonly used in workshops for air tools, blow guns, and tire fillers.
I added a valve so that I could detach the supply without blasting out all of the gas. It is a nice feature but not required.
See the picture, it's pretty obvious.
Step 4: Add a Gasket to the Plate
in order for the gasses to stay in the bottle during carbonation, you'll want a gasket.
I tried
automotive RTV gasket maker
100% silicon sealer (caulk)
glued-on bike inner tube
the bike inner tube works the best. It's not pretty.
It imparts no flavor to the product, and if you have a more food-grade gasket, that would probably be better.
I contemplated cutting up my wife's silpat cookie sheet, but I like being married.
I tried
Step 5: Make Soda
so now you are ready to make it.
Get your bottle of water from the fridge.
Open the cap
Attach the assembly and screw the clamping screws on tight. Just tight, not overly tight.
close the valve
attach the CO2 line
open the tank valve
adjust the pressure on the regulator to about 50 PSI
open the valve on the bottle.
Check for leaks, and hisses.
Shake the bottle for about 30 seconds to a minute (more shaking == more fizz )
close valve on bottle.
Disconnect quick-release
close CO2 tank valve.
open bottle valve slowly
remove assembly
enjoy bubbles.
Open the cap
close the valve
attach the CO2 line
open the tank valve
remove assembly
enjoy bubbles.
