Make Your Own Windows 10 Bootable Dvd From the Upgrade Files You Get by Upgrade Windows 7/8 to 10
Intro: Make Your Own Windows 10 Bootable Dvd From the Upgrade Files You Get by Upgrade Windows 7/8 to 10
OK, you got yourself a nice Windows 10 running but, there is always a "but", you don't have a installation DVD, and it takes much more time to install Windows 8 and then upgrade it to Windows 10.
Now how to fix this ? EASY, you just follow my step by step guide and you are fixed.
STEP 1: Enable "Show Hidden Files"
FIRST ENABLE SHOW HIDDEN FILES IN YOUR EXPLORER.
Windows 8 procedure:
Access the Control Panel. ...
Type "folder" into the search bar and select Show hidden files and folders.
Then, click on the View tab at the top of the window.
Under Advanced Settings, locate "Hidden files and folders." ...
Click on OK.
Hidden files will now be shown when performing searches in Windows Explorer.
Windows 10 procedure:
Open Folder Options
by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
Click the View tab.
Under Advanced settings, click Show hidden files, folders, and drives, and then click OK.
STEP 2: Locate Update Files & Build the Image.
When you initiated the update procedure, ii downloaded the Windows 10 files, "somewhere". That "somewhere" is
C:\$Windows.~BT
Strange name huh ? Now enter that folder and locate a folder called
Sources
Inside there is a single file that we need it is called [see image 1]
install.esd
Now we need to download a nice little program called ESD-Decrypter, you can get it from here or from the makers one drive (http://1drv.ms/1HeQkW0)
Extract it with 7-Zip (http://www.7-zip.org/).
Now copy install.esd to the extracted folder. [see image 3]
Now go to that folder and RUN AS ADMINISTRATOR the file called decrypt.cmd
Choose option 1 (Create Full ISO with Standard install.wim)
Wait
Done [see image 3]
When installing, it may be necessary to use a CD-KEY (for the Insider Preview version it was necessary).
If you need here are the public keys they provided (those are not pirated keys or something like that)
Windows 10 Home Insider Preview build 10158 product key:
KTNPV-KTRK4-3RRR8-39X6W-W44T3
Windows 10 Pro Insider Preview build 10158 product key:
8N67H-M3CY9-QT7C4-2TR7M-TXYCV
Windows 10 Enterprise Insider Preview build 10158 product key:
CKFK9-QNGF2-D34FM-99QX2-8XC4K
Note that these keys should work with later builds as well.
I MADE THE ISO WITH THIS PROCEDURE, I BOOTED THE DVD AND IT WORKS, BUT I DID NOT STARTED THE INSTALLATION FROM IT (I JUST GOT WINDOWS 10 ON MY PC TODAY) THAT'S WHY I DON'T KNOW IF IT THE KEYS ARE STILL REQUIRED. I WILL TEST IT SOON AND UPDATE THE TUTORIAL.
2 Comments
Tvfbeo9r 7 years ago
Guys who need windows 10 key can go link http://windows10keydownload.tumblr.com to got. My key got here and after i used is great works. Hope it can help you.
Aline9 8 years ago
Thanks guy! It's
helpful! And friends you can also get your windows 10 upgraded from www.aakeys.com . It's
convenient and easy to finish the upgrade process with this site.
