Introduction: Makedo Pizza Box Gramophone
Planning a pizza night in? Boy have we got a fun project for you. Here, we show you how to turn your pizza box into a Makedo Gramophone that really works.
All you need to make this amazing musical creation is a pizza box, some paper, a pencil and pin, plastic lids, an old vinyl record and Makedo parts available from mymakedo.com.
*Warning*
This DIY record player could damage fragile records. Although it will successfully play music, we recommend only using it on old albums that you (or your parents) won't miss if they get ruined.
Why does this happen? It's because the pin we are using to read the record is not as delicate or sensitive as a commercial record player needle.
We suggest buying some old records from a yard sale or thrift shop to use with your Makedo Gramophone.
*Warning*
Step 1: Gather Materials
Collect the materials you'll need to create this working gramophone.
Step 2: Create the Cone
Roll up the piece of paper into a cone shape and hold it in place using Makedo Re-clips.
Use the pin to pierce through the end of the cone.
Step 3: Create the Cone Support
Use 3 Makedo Lock-Hinges and connect them together with Makedo Re-clips as shown in the image, making a Y shape. Place the cone on top of the Y shaped Lock-Hinges and connect it using Makedo Re-clips.
Step 4: Connect to the Box
Now connect the hinge to the top corner of the pizza box.
Step 5: Prepare the Vinyl Record
Using the Makedo Safe-Saw, Punch holes in the centre of the yogurt lids. Place your pencil in the punched holes with the vinyl record sandwiched between.
Step 6: Attach Record to the Box
Punch a hole in the top of the pizza box to position your vinyl record.
Place the pencil in the punched hole to complete!
Carefully place the pin on to the record and slowly turn the pencil as you listen through the cone. Play your favourite old tracks. Don’t forget to share your creation at mymakedo.com. We would love to see it!
