Introduction: Maker Vs Arduino UNO
Everybody knows arduino uno but as elementary teacher, leaning hardware programming can be challenging. Tiny jumper cable connection prove to be a challenge to their small hands and may destroy the board if wrongly connected. With that in mind, I have made a video on maker uno which make the children to the actually coding rather than tweaking with cables which is reserved for older students at https://youtu.be/yCF2LiYm1WA
For your info, Arduino Uno is a microcontroller board based on the ATmega328P (datasheet). It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz ceramic resonator (CSTCE16M0V53-R0), a USB connection, a power jack, an ICSP header and a reset button. Maker Uno on the other hand is an Arduino Compatible board specially designed to simplify building your projects: Coding & Electronics made easy with built-in:{ 12x LEDs; 1x buzzer; 1x button; } Troubleshooting made easy with LED indicators.
Step 1: Explanation About Maker VS Arduino UNO
