Introduction: Makeup Phone Cover
Have you ever woken up late, with just enough time to wash your face before running to school / work, or looking in the mirror after a few hours out and seeing that your makeup needs a touch up and not knowing how to do it, don't having the necessary tools with you? It happened to me often, and I decided to create this practical cell phone cover with tricks, so you always have them on hand!
-Cellphone cover
-needle
-scissors
-small rubber bands
-tape
-glue
-small makeup supllies
-needle
-scissors
-small rubber bands
-tape
-glue
Step 1: Step 1: Placement
Place the objects as you like on your cover, creating all the combinations you want
Step 2: Step 2: Holes
Pierce the cover with the needle at the points where you want the supports for removable objects, in this case the brush and the eye pencil.
Do not make the holes too far apart, as the diameter of the object they have to keep in Place Is small.
Slightly spread the holes with the tip of the scissors.
Step 3: Step 3: Inserting Supports
Cut the small hair elastic in half and insert the ends into the two holes you drilled before, fixing them with adhesive tape.
Step 4: Stap 4: Glue
Now, put glue on the back of any non-cylindrical object, in this case the small palette, and glue it to the cover. If you have hot glue it's better, but super glue will work just fine.
Dry the cover with a heavy object on it, so that the palette adheres well.
Step 5: Step 5: Finish!
Place the objects and you're done! Now you can always carry your makeup supllies with you everywhere 😊
