Introduction: Makeup Tips for Close-Set Eyes
http://www.styleunited.com/TipsAndTrends/article/Makeup-Tips-For-Close-Set-Eyes If your eyes are close set, you can make them appear further apart with some makeup tricks that we cover in this video.
Step-by-Step:
1. Eye Makeup Prep: You need to prepare your eyes before applying makeup. Olay Regenerist Anti Aging Eye Roller is good to apply to reduce puffiness and achieve a brighter, more youthful eye.
2. Eyeshadow: To make your shadow last all day, first use a cream shadow with a primer. We recommend CoverGirl Shadow Blast with a built-in primer. Next, use a powder shadow palette like CoverGirl's 4 Kit. The lighter color is used to set the cream shadow already applied, only concentrate this color in the corners of the eyes and brow bone which opens up the eye. The middle color shadow should be applied all over the lid. Use the darkest contour color to the outer corners of the eye into the crease. Make sure to use a fluffy brush to blend it all.
3. Mascara: Finish with mascara. Here we have used CoverGirl's Lash Perfection on both the upper and lower lashes to make your eyes look further apart.
4. Lips: Always finish your look with lip color. We recommend CoverGirl NatureLuxe Gloss Balm.
Step-by-Step:
