Introduction: Makey Makey Interactive Solar System
I chose to make a solar system to inform the public about the planet there, order, relative size, and color.
My project uses copper tape and wire to create a circuit. This circuit allows for when clicked to say the name of the planet that is being pressed to educate on the order and names of the planets and the sun.
Copper wire
Aluminum foil
Playdoh Cardboard
Hot Glue
Copper tape
Tape
Small CD
Ping pong balls
Black marker
Step 1: Step 1: Coding the Project
Create 9 sprites of all of the planets and the sun
Step 2: Step 2: Coding the Project
Add a space background of your choosing
Step 3: Step 3: Coding the Project
Create 9 different broadcasts for each different planet when a respective key is pressed (e.g. sun, space; mercury, up arrow; etc.)
Step 4: Step 4: Coding the Project
For the broadcast corresponding to the planet, have the planet increase in size by your chosen amount and move to (0,0) wait one second then move back to its respective position
Step 5: Step 5: Coding Project
When a broadcast is happening that does not correspond to the planet, those planets should hide wait one second then show
Step 6: Step 6: Creating the Project
Create 6 planets increasing in size (not Saturn and Jupiter) with tin foil
Step 7: Step 7: Creating the Project
Cover ping pong balls with tin foil to make Saturn and Jupiter
Step 8: Step 8: Creating the Project
Make Saturn's ring out of CD and Uranus's ring out of tin foil
Step 9: Step 9: Creating the Project
Poke holes into the planets using the copper wire
Step 10: Step 10: Creating the Project
Decorate and cover planets in playdoh
Step 11: Step 11: Creating the Project
Make a tin foil ball bigger than the rest of the planets and cover it with playdoh to be the sun
Step 12: Step 12: Creating the Project
Gather 8 pieces of copper wire and cut copper wires to desired length (preferred decreasing in size)
Step 13: Step 13: Creating the Project
Attach the copper wire to the planets (starting with the shortest for mercury and so on)
Step 14: Step 14: Creating the Project
Create a circle out of cardboard and mark 8 equally spaced parts (can use a compass)(can color the ring black)
Step 15: Step 15: Creating the Project
Glue the copper wires with the planets onto the cardboard ring
Step 16: Step 16: Creating the Project
Glue the sun to the center of the cardboard ring
Step 17: Step 17: Creating the Project
Attach copper tape around the planets connecting to copper wire (for sun left off the edge to connect to the clip)
