Introduction: Making 1 L Hydrogen Per Minute at Home Using Water
Well I have been making various projects and codes for a few years . So I had a lot of old not working pc's including a dell optilex . I always wondered can I make something using it here's what i made
What do we need for this project -
1: Dell Optilex Cabinet
2: Power Supply Unit (650w) two or you can choose dc batteries 9v 9a
3: Blades X40
4: Some wires
5: Hot Glue Gun Or Fevikwik
6: Some Wax color pencil
7: Tools
8: Some small pieces of plastic
Step 1: Removing Everything From Dell Optilex
First we are going to remove the motherboard and everything else from the computer then remove everything from it including screws .Then cover it with extra plastic including the i/o ports
Step 2: Joining the Pencils With Blades in the Cover
Now first we are going to join the blades into the pencils by making small cuts in them using cutter and then put a blade in it and apply fevikwik or hot glue gun and then join them to the base of the cabinet
Step 3: Doing Wiring
In the wiring we are first going to choose any half of the pencils with blades and join them together using wires and connect them all together to join and mark it as positive and join other blades using other wires and join them and mark it as negative
Step 4: Finalyzing It
Now first we are going to take the top part and make a small cut and a small filter pipe and join it with it and place it over the lower par with blades . Make some small holes for both positive and negative wires and get them out and seal them with hot glue gun
Step 5: It Is Insane
Well after making it tested it and then checked its ability but for that first we are going to make HHO by combining distilled water and salt and put it in and test it out and the results were insane it produced 1l of hydrogen and oxygen gas per minute and this is insane . So now lets just blow off some water bottles or other plastic bottles
