Introduction: Making a Kettle Using CAD
In this Instructable I will show you how to create a classic kettle body using ProEngineer(Wildfire 5).
**NOTE**- I understand that I am missing the spout at the moment as it will require more advanced skills (hence taking more time) and shall be added soon.
Step 1: Drawing the Base
First, open a new 'part' in ProE. Next select sketch mode from the top right hand corner. Select the front datum plane and click OK to start your sketch.
Draw two lines like shown in the image. Mine are set at 150mm(Line 1) and 25mm(Line 2) with a 110 degree angle. This will help make the general shape of the kettle.
Next right click(RMB) and select 'Centreline'(Line 3), then rotate it until it is horizontal. A red H will appear to confirm this. The distance between this line and Line 2 will determine how tall the base of the kettle is. I set mine to 200mm.
Next, select the spline tool on the right (The squiggly line) and draw a line(Line 4) from the end of Line 2 to the point where Line 3 meets the y-axis. Middle mouse button (MMB) to deselect the tool.
Next use the tangent tool to make the curve. To make the curve, first click near the top of Line 4 and near point on Line 3. Then repeat the process at the bottom of Line 4 with Line 2.
Make sure you join Line 3 to the left end of Line 1(Makes Line 5).
Press the blue tick to confirm and exit from sketch mode.
Next you need to use the revolve tool to make your sketch 3D.
First, select Line 5 and click on the revolve button.
Press the green tick to confirm your revolve.
You now have a base to your kettle.
Step 2: Drawing the Handle
First, you need to start a sketch on the front datum plane as you did in Step 1.
Next draw two circles so that they make a handle-like shape.
Then you need to draw a two lines between the two circles - one on each side.
After this, you need to use the delete segment tool to remove the rest of the circles that are below the two lines.
Then, OK the sketch and find the extrude button on the right tool bar.
Click the extrude button. This will make a extrusion that sticks out to the site of your 2D drawing. You need to adjust this so that the extrusion comes out equally from both sides. You can do this by selecting the drop-down menu from the extrusion tool bar at the top of the window. Click the second option in the drop-down menu. This will create an equal extrusion that will be aligned with the kettle body. You can adjust the size of the extrusion by double clicking the measurement that stems from the shape.
You now have a kettle body and handle that can be adjusted to your preferences.
