Introduction: Making BioPlastics, Environmentally Friendly Plastics
This is my first instructable so please try not to criticize to harshly.
BioPlastics are plastics that can be made out of common household products.
These are to the environment in that they contain no petroleum unlike usual plastics such as tupperware etc. Also instead of taking about 100 years to fully decompose it only takes about 7.
There are probably other instructables about BioPlastics out there, but I made some for a school project so I decided to make an Instructable
Step 1: Ingredients
Here are the ingredients that I used...
-Corn starch
-Water
-vegetable/Canola (Optional)
-Wax Paper (optional)
You will also need a microwave.
And measuring tools
Step 2: Mixture
The Ratio I mixed with was 1 part corn starch and 1 part water. Feel free to change this based on the use of your plastic.
For a more rigid plastic, add more corn starch.
For a more flexible/ squishy plastic add more water.
I mixed them in a sandwich bag.
If you want to add in some vegetable or canola oil (I used canola) and it will help keep it together a little bit
for every 2 cups of MIXED water and corn starch I added 1 tablespoon of oil. But of course you can change this based on your intended use of the plastic.
Make sure to get all the bumps of corn starch out you want it to be completely dissolved
It should look a bit like milk.
Step 3: Microwave the Mixture.
For a mixture totaling 2 cups (1 cup water and 1 cup corn starch) I nuked it for about a minute.
This of course could change based on the wattage of your microwave. I believe that mine is some wheres around 1000 to 1400 watts (ya i know thats pretty broad).
If your not sure how long to keep it in for just watch it until it turns to a solid yellow color.
The longer it is in the less flexible it will be but be careful not to leave it in to long or it will become very brittle and crumbly.
WARNING: BE VERY CAREFUL WHEN REMOVING THE MIXTURE FROM THE MICROWAVE AS IT WILL BE VERY HOT AND MAY REQUIRE 5 MINUTES TO COOL DOWN !!!
Step 4: Molding It
Congrats you have just made BioPlastic. But wouldn't it be cool if you could make shapes out of it or even containers ?!?!?
What I did was I put a cookie cutter on some wax paper then poured in the BioPlastic mixture before I cooked it. When i realized that it was leaking a little I just put some tape around it and it was fine.
If you really wanted to get creative you could make a mold out of a microwaveable safe material (fired clay) and you could make some pretty neat containers.
Step 5: Yay You're Done
Well done you now know how to contribute to the environment by making plastics that do not harm the earth. Happy Earth week! and don't forget to vote!
Note:
This particular batch turned out to be more of a rigid gel type material.
If I had added just little more corn starch and kept in the microwave longer then it would have been more like a hard plastic.
Also once it dries completely you can run it under water without it falling apart, but I would not put it in the dishwasher.
Earthjustice United States of Efficiency Contest
2 People Made This Project!
- Ignacio2002 made it!
- jwinans1 made it!
49 Comments
2 years ago
Im also trying to make a bioplastic phone case and I badly need to know your mix. Please? Thank you.
3 years ago
Once the plastic has been made can you reheat it to manipulate it's shape?
3 years ago
Hey, so im planning to make a bioplastic phone case and just read your comment. May i know your mix? It would be a great help in my project thank you
6 years ago
OMG me tooo!
Reply 6 years ago
im notta girl do
6 years ago
cool
6 years ago on Step 3
what is it intended for
6 years ago on Introduction
can you substitute corn starch with other fruit starch example, papaya starch? will it still work?
I made it! (i'll post it soon). Also, could you make plastic bags with it?
7 years ago on Introduction
Could this be made into 3d-printer filament?
Also, about how dense is this plastic and how strong is it without some kind of scaffolding?
Wow nice instructable dude :D
7 years ago
Is it okay to add fiberized corn silk and husk?
7 years ago
lile by pouring it and then smoothing it out over a surfboardcore
7 years ago
do think this could be used for the shell of a surfboard?
8 years ago on Introduction
thanks! I'm going to use this for my quad copter base
12 years ago on Introduction
first, This looks AWESOME, also, what would the substitute time be for a convection oven (regular oven) (i don't have a microwave, sad, I know). BTW, how hard is the plastic when cooked (comparisons).
I wouldn't use a conventional oven... The transfer of heat in an oven heats the outside much quicker than the inside. This will cause all sorts of mayhem with the shape and can cause it to basically rip itself in two :(
10 years ago on Introduction
I really need to know if there would be side effects when i add shrimp shells, please do help me.
Did you ever try it? My guess is that the chitin in the shells would make it harder but probably more brittle... Please let me know if you tried this, I'm curious now
