Introduction: Making Cuddly Candies: Part 2, Giant Marshmallow
I made I giant marshmallow, and then gave it a baby brother. I made the little one with Dusk Shadows, actually I just told him to sit down and eat his cake while I did all the work. It was gooood cake. I guess the inspiration for two came from Totoro, cause there are two little Totoros and one big one.
For the first "Making Cuddly Candies," view here
Step 1: Cut Out Your Pieces
You need one long rectangle and one circle.
Formula:
You can make your marshmallow any size you want, but you must follow this formula. The diameter of the circles must be the same as the height of the rectangle. The circumference of the circles must match the length of the rectangle.
This is so it will be the right shape.
Also, if you don't already know, the procedure for the eyes is somewhere....Here!
Just remember, leave a little bit of room for the seams!
Formula:
Step 2: Sew It
First sew the ends of the rectangle together, just a straight line over the folded up piece. Then pin your circle to the rectangle (should be in a circle shape) and sew round. Then do the same for the other side but LEAVE SOME ROOM TO STUFF IT.
Push it inside out through the hole you have left.
Step 3: Stuff It!
Use fiber fill of hobby stuffing or whatever to fill the marshmallow. Make sure you push and stuff the edges as much as you can, then fill up the rest. If you want, draw on a mouth.
Step 4: Finished!
If you want, make a little one. I gave it a bow tie! You are done! Hurray! Now step back and admire you work.
