Making Electricity in Your Hand
Intro: Making Electricity in Your Hand
In my research to make an alternator for my Savonius VAWT wind power project, I learned there is a great deal of mystery around making them. I even read one article that referred to home brew alternators as a dark art shrowded in mystery. I dont think it is all that poetic but I did agree that for a novice with no real electrical background that it seemed a mystery. Kind of like a cookie recipe, you know there are things like flour, eggs and sugar, but how does it go together? What job does each ingredient do? How is it mixed or assembled?
From my experimenting, which is not over by the way, I found that this simple excercise was the most revealing.
You will need a huge magnet like used in a wind power project. The rest is available through normal hardware store or RS. I'm sure a good sized speaker magnet would probably work if you have a sacrifice to make.
1 small spool magnet wire (about 30 feet of 24AWG)
1 bulb from or for a keychain flashlight (two refills for $1 around here)
1 Neodymium magnet 1inch x 2inch and 1half inch thick (about $10 plus shipping and any tax)
STEP 1: Get Wire Off the Spool and Re-wind It
This seems like a goofy idea, the wire is already so neatly wound on the spool. The problem with the spool is the big hole in the middle. You need to re-wind the wire with a nice small hole and relatively flat.
The idea is to expose as much wire to the highest concentration of magnetic field as possible without shorting the wire in the coil. This is why we use magnet wire. It isnt magic wire that makes electricity, it is just that magnet wire has a much thinner sheath and its usually made of enamel.
The extra thin sheath allows you to cram more wire in the same space as you would regular wire.
The attached mov file is my drill coil winding jig in action.
STEP 2: Why Wind It Flat?
Well, optimally you would wind it to be the same shape as the magnetic field that will go over or past it. My magnet is rectangular and relatively thin. So for this instructable, make the coil about 1quarter of an inch thick or half the thickness of the magnet.
Magnetic fields drop off with a very high curve. They are strongest when in direct contact with a surface. This is why we want to put our wire into a shape similar to the magnet and be able to get it as close as possible for exposing the coil of wire to the magnetic field.
In commercial applications, there would be a metal in the hole of our wire coil. We are not going that far. It is there to draw the magnetic field more completely through the coil. More efficiant in some ways. Not here.
STEP 3: Now What? Its Wound Flat... Sort Of...
Probably good enough for this simple experiment.
Tape it up with two leads hanging out.
I know the image isnt the sharpest, but we are looking at one lead from the coil. I stripped the end with some sandpaper and then coiled it around a small screwdriver.
Do this or something similar to strip both ends and make a couple of tight loops. This is not critical, it just gives us a point to attch the light bulb without soldering.
STEP 4: Remove Bulb From Flashlight or Packet If You Purchased One...
You want to put one leg from the bulb into each prepared coil lead. Then pinch the coil snug on the leg to hold it. This is just an experiment to illustrate the process of making electricity. If you like, you can make a more significant attachement. I found this worked fine while I would wrap different shapes of coils and check the voltage I could generate.
STEP 5: Hold the Coil and Strike the Magnet Here Come the Electrons!
If you are familiar with lighting a match, this next motion is similar.
While holding the coil in one hand, hold the magnet in your dominant hand and slowly motion the magnet past the coil. This is to visualize what you are about to do quickly and to make sure your thumbs are not in the way or the two wire leads. If anything is in the way and might get caught, adjust accordingly.
Now as you will pass the magnet swiftly over the coil, you want to get as close as you can without hitting it. The flat side of the magnet face to face with the flat side of the coil. This is a side to side, not up down motion. The speed the magnet passes has an effect on the voltage created. You will feel a vibration in the coil when everything works right. This is NOT electricity flowing through your hand. It is a ripple effect or vibration from the coil making sudden drag on the magnet and the leads hanging out.
If you move the magnet past fast enough and your contacts are good and you have enough length of wire in your coil, your light should blink on with each pass.
STEP 6: An Alternator...
An alternator creates Alternating Current or AC. Many alternators use all coils and no permanent magnets. You will need to research this if you really must know how they work. The power we just made in our hand is a permanent magnet generator or PM generator. I wont call it an alternator because we are not flipping the magnet at each pass to alternate the north and south sides.
When you build a wind power generating machine, you are putting together a team of these coils and wireing them for optimal performance. Then you are mechanizing a motion of the permanent magnets to blast past the coils as the machine turns in the wind. Thats the summary.
Check out my savonius rotor project PDF for more details on the alternator.
The attached mov file is my hands striking past the coil and the bulb lighting up.
60 Comments
lgallagher4 11 years ago
The Bulldog 12 years ago
Bluexadema 14 years ago
it makes sure the whole contact is clear and its much faster, decent instructable though
bhunter736 14 years ago
jonafrank 14 years ago
El Mano 15 years ago
joe_61 14 years ago
knight life 15 years ago
DanLoney 16 years ago
bhunter736 16 years ago
RyanPotter 17 years ago
scotty3785 17 years ago
bhunter736 17 years ago
girrrrrrr2 16 years ago
maffiou 16 years ago
