Introduction: Making Gemstones With a "Pop It" Toy
In this Instructable, I will answer a question that nobody asked: Can you use a "Pop it" fidget toy as a gemstone mold?
The little domes that you press with your fingers seem to be the perfect shape and the silicone material should be ideal as well.
This tutorial might seem a bit random, but you can use the mentioned techniques with any silicone mold!
- Pop it fidget toy
- hot glue or (UV) resin
- acrylic paint or nail polish (especially shimmery colors)
Optional:
- baking paper
- glitter
- clear nail polish
Step 1: Testing
First, I tested filling the concave areas with hot glue. The front and backside of the toy look slightly different.
I suspected side 1 to work better as a mold and turned out to be right (at least I preferred the results from side 1).
A small problem is that the hot glue creates a dome, so the gems won’t lie flat.
So I decided to press the glue down with little discs of baking paper and a fitting flat object.
Step 2: Painting the "molds"
Next, I wanted to see what happens if I paint the molds before adding the glue.
I found out that you can create interesting patterns by making the paint watery. I let that pattern dry and coated it with more paint.
I used my trusty nail polish as well, because it dried quicker than the acrylic paint and was also more opaque.
Step 3: Hot Glue
Then I just had to fill the molds with glue. As tested before, I covered the glue with the baking paper discs and pressed it flat.
Step 4: Pop It!
Popping out the gems worked really well. No paint was left behind in the molds and the gems came out looking very smooth.
This is a good trick for silicone molds in general - no matter how many layers of paint you use, the result will come out smooth and the shape won't be affected!
I just needed to trim the excess glue.
Step 5: Glitter
To make glitter gems, the best way I found was to coat the mold with clear nail polish and to sprinkle the glitter on top. (Glue works too, but the finish wasn't as smooth)
You can add a layer of matching paint on top as well.
Step 6: UV Resin
There was one more thing I wanted to try - UV resin.
I tried to be a good example by wearing gloves, having good air ventilation and even wearing a mask - thanks to my husband who likes to remind me of the importance of safety measures ;)
Of course I glued the lid of the nozzle shut with resin, so I had to pour the resin straight out of the bottle opening.
I got the best results when I didn’t fill the mold completely at first. I filled the area about halfway, swirled the resin around to coat everything and cured it.
Then I topped it up with more resin and cured it again.
My UV light is meant for nails - I got it second hand for 5 pounds. I’m still happy about that - it works well for small projects.
Step 7: UV Resin Results
As expected, resin is hard to beat when it comes to looks - the gems turned out nice.
Because this Pop it has a matte finish, the gems came out matte as well.
By the way: Of course, after using things like resin on the toy, I wouldn't let kids play with it - especially little ones.
Step 8: Optional Varnish
I wanted to see if I can make the gems clearer with clear nail polish. And it worked even better than I thought!
Step 9: Shimmer!
An easy way to add color to the resin gems is to paint the bottoms. Shimmery colors will give the gems a nice shifting effect.
Well, maybe you found something useful in this Instructable. Or maybe not. Either way, thanks for checking it out!
