Making Half Blind Dovetail Drawers for a Walnut Desk
Intro: Making Half Blind Dovetail Drawers for a Walnut Desk
Using half blind dovetails is really great for certain projects like making drawers for example. Half blind dovetails don't go all the way through, like through dovetails so you can't see the dovetails until you open the drawer. I made four drawers with half blind dovetails for a desk that I built, so I wanted to go over the process of how I made them.
STEP 1: Choosing Your Wood
For the frame of the desk I'm using walnut, so I'm going to be using walnut for the drawer fronts as well.
Now there are lots of different ways to build drawers. You can butt join them, or use pocket screws. However when it comes to strength and beauty, you really can't beat dovetails. Half blind dovetails are really nice when you don't want a seamless front, so that's what I'm using for this project.
STEP 2: Building the Drawers
For the sides of the drawers, I wanted a nice strong, contrasting wood, so I ended up with maple which I resawed into thin 3/8 inch pieces. So I'm cutting the side piece to length, and here I'm using the one side to mark the other side of the other tails so they're exactly the same.
Mark out your tails. I'm using my first piece of wood to mark out the other boards, so they'll all be consistent. You can choose the angle you want, depending on the look of your project and your preference. Common angles for dovetails range between 7-15 degrees. Also decide how many tails you'll need, that will depend on the size of the board that you're working with. Mark an x on the pieces that need to be removed.
STEP 3: Marking the Tail Board
When you have your dovetail lines in place, make sure to bring the marks across with a pencil or a knife.
Next, I'm marking the baseline of the dovetails with a marking gauge. This will determine how long the pins will be. This is also the distance of how far the tail board (the maple) will go into the pin board (the walnut).
There is a lot of customization possibilities here. You could really place the maple anywhere on the walnut expect at the end to still be half-blind.
STEP 4: Cutting Out the Tails
To cut out the dovetails, I use a rip saw, and it's a good idea to cut on the outside of the line (on the side of the x).
Once the dovetails have been cut, I place the piece in the vice and cut the sides off with a cross-cut saw.
To remove the waste in the middle I use a coping saw, make sure to cut rather quickly because you can't change the direction if you're going slowly. Make sure to stay within the lines!
Finally, clean up up the lines with a chisel.
STEP 5: The Pin Board
Now once the tail board is done, it's time to move on to the pin board. So I'm setting the walnut down flat in the vice, and I'm laying the maple right on top, marking out where the pins need to be.
Next I'm setting my marking gauge, and marking out the pin board, and bringing the lines down.
Then I'm cutting the pins at an angle with a rip saw, because I can't go all the way through. Since these are half blind dovetails, it's a little trickier than through dovetails, because the tails will fit inside the walnut, and won't show on the other side. So I can only chisel down so far, so I have to be a bit careful so I don't take out too much.
For this job I find it really nice to use a small mallet that's easy to control. Once I have some of it chiseled out I place it in the vice and chisel that way, being really careful to not go down too far. This is pretty time consuming, because you don't want to crack the wood and you want to stay within your lines.
Carefully chisel out the area until you have a clean pin board ready for the tails.
STEP 6: Assemble
I routed out grooves on the maple so I could fit a piece of hardboard for the bottoms. I also cut out a piece of maple for the back.
Once I had all my pieces I glued the dovetails together, slipped in the hardboard bottom, and nailed in the back.
STEP 7: Conclusion - Watch the Video
For a much better perspective, make sure to check out the video where I do the half blind dovetail drawers for a desk.
35 Comments
k8e 5 years ago
nhampto9 8 years ago
It seems to me that cutting wood is cutting wood. Hand sawing & routing both do the same thing. A handsaw is quiet & slow. A router is fast. The handsaw requires three cuts to remove the dovetail. A router requires only one.
I don't know why people are such glue fans either.
Last a few years? I made twin bunkbeds. The novelty wore off in 3 months. Separated to two beds. Room rearrangement left them sharing again. Bed frame got transferred to a queen size bed. Another rearrangement left no room for the frame so it was dismantled & finds life as a wardrobe. That's less than 1 year! I'm not aiming for 400 years, just next month.
If I have 3 hours to build X, then I don't have time to waste on slow methods.
Never been to an Ikea so I wouldn't know. Other than nails & screws, my cost is negligible.
So, again, why dove tail? I bought a new router to learn to use it. I own a Kreg jig but haven't used it yet.
Trust me. A machine in my hands shows plenty of 'frailty'.
misterxp 5 years ago
Sorry I
am not an expert furniture maker myself but I think that the answer to your
questions "why…..etc etc" is that this is the difference between a
craftsman / woman and industrial process. Of course it is quicker and easier to
use certain methods but a really beautiful piece of work is made by a
craftsman/ woman or artist. It is also probably possible to make a "Monna Lisa" quicker with a computer but the
end product is different. In my humble opinion, I think that darbinorvar
produced a beautiful and unique piece of art and not just another piece of
furniture….that is my opinion but I respect your views too. It is just a
question of points of views.
Congratulations and thanks to Darbinavor for the instructable!
bjm1950 5 years ago
Because some people enjoy the challenge and satisfaction of producing a finished product like that!
I wish I could do them so well.
IngenuityAtWork 8 years ago
millergray 5 years ago
I have a reason why I, when making furniture professionally, would not use a router. Most of my projects were one of a kind and would rarely have more than eight drawers. The times I tried jigs I found that the good ones, which allowed custom sized adjustable pins took quite a while to set up, and I realized I would have been nearly done with the handsawing before I even felt confident enough in my setup to turn on my router. I also had a few disasters where something went out of alignment halfway through. Which is the downside to routers, you don't know if something is going wrong until it's way too late. I think when you go into double or triple digits of boxes, it's no contest, use the jig. for just a few, go with what drives you the least crazy. for some that's a chisel, for some it's a router and jig.
2) Why not use a router?
So far, the only answers I've been able to find is "tradition". That doesn't cut melted butter w me.
max_brasil 5 years ago
One reason is because working with our hands is not necessarily about "having" something. It's about the process and, for me, an escape from a high tech day job. If you want something, go to a big box store and buy it. It will take far less time than building it and be cheaper, too. I am not a professional woodworker, so I'm not under time constraints and happen to enjoy creating furniture by hand in a quiet, dust-free shop. Kudos to the original poster - nice work!
srilyk 8 years ago
Dovetails are a surprisingly strong way to join wood. If you ensure a snug fit you actually don't need adhesive.
As for not using a router... some of us decided to spend our money on good hand tools instead ;)
stoobers 8 years ago
If you go through the trouble to make a drawer, and you use a router and jig to cut the dovetails, the money you spent on wood is lost, as you cut the wood up into pieces and glued the wood back together again. A few years from now, what you made ends up in trash. Don't waste your time joining with a router. Its a lot of work, and has no payoff, as you can get stuff much fancier mass produced at Ikea for less money.
But if you make the same thing by hand and join it by hand, the value of the wood goes up, and other than the age, looks like every antique made for the past 400 years. The joint is far stronger than screws (look up 'kreg jig').
Also, making dovetail joints on a router isn't as easy as making toast - lots of ways to destroy expensive wood quickly. There are size limits to the jigs, which are not present when working by hand. Also, dovetail joints aren't really too hard, they just take a while.
I don't even bother with electric saws anymore. It is better to have the imperfections show as a sign of human frailty than to try to keep up with the jones.
darbinorvar 8 years ago
Well, first of all, a router is not a joint. Secondly using a router to do half-blind dovetails is pretty annoying. Thirdly, when you build yours you can choose whatever method you want. Check out the video linked above if you want to see my reasons.
charlessenf-gm 5 years ago
Why did you not use a single board for teh drawer fronts?
Sam_NY 5 years ago
Are you asking as an honest question, or do you mean it more like a statement (e.g. "I would have used a single board for the drawer fronts.")?
rolaugh 7 years ago
Nice work.
amberharding82 8 years ago
Durable :)
Murray and Michelle 8 years ago
Very nice job. Love the workmanship. Very very nice!
mkronman 8 years ago
When I saw the preview, I was thinking that this is going to be yet another "How to use a router" instructable.
I was wrong. Awesome!
heavyweather 8 years ago
Thanks!
Basel Brush 8 years ago
You are a very talented person, I envy you your skill.
