Introduction: Making Little Teddy With Real Pattern Doll Hand Sewing
About: Im Eric Dirgahayu , im a robot maker at diy project
Teddy bears are the most famous dolls in the world, she's cute soft and adorable, But bear not the only doll there, but there are other dolls like barbie dolls and else.
How if the beautiful dolls have cute teddy bears as well, for that we will make a little teddy bear that looks and patterns similar to the original doll.
This is a mini version of the howjoyful bear, for accesories barbie or BJD doll scale 1:6, 1:12.
  • The real size doll pattern you can download at https://www.howjoyful.com/howjoyful-bear-tutorial-and-pattern/
  • Hand sewing set
  • Hot glue gun
  • Permanen Black marker
  • flannel fabric, select the color you like
  • silicon dacron
Step 1: DownScale the Fattern
In the Supplies there are link to download the real size fattern, you can download and resize to the mini size, i choose downsize to 35% of the real fattern, this size suitable for doll size accesories scale 1:6 or 1:12, i have added the 35% downsize fattern in this step, you can print and cutting all pattern. For all of those that say you need 2, 1 reverse; after tracing the front, turn the pattern and trace the second piece. draw the pattern to the fabric and cut, give a little distance when cutting fabric for seam space.
Step 2: Making Head
There are name tag on the fattern, find the ear fattern, for this mini doll you do not need to make 2 layers of ears, just with 1 strand of cloth, cut according to the pattern for 2 pieces of ear.
Look for patterns with the name of the side head there are 2 patterns that are reversed, and 1 front head pattern, sew all the patterns like a sewing image from the ear first, this use a hand sewing because is very small you can use basic techniques.
attack the moth fattern onthe head after that next to attach the back head.
Step 3: Making a Body
Sewing patterns of the belly and legs top as in sketch drawings, Sew according to the letter code of the fattern,
make a hand first before attaching to the body, sewing the hand pattern according to the letter code, after hand finish atach the hand the the body and last attach the back body to the body up to sewing into the feet.
Step 4: Filling the Dacron
Before uniting the head and body contents first head and bada doll with silicon dacron, fill until fit with doll size.
after filling the dacron, put head and body together by sewing it.
Step 5: Make Eyes and Nose
im use a hot glue gun for making eyes and nose, Make a small point ball in the eyes of the doll and also on the muzzle of the doll's nose, color with a black permanent marker, or a color you like
Step 6: Finish
All Done,
Thankyou.
