Introduction: Making My Own Recipe Cards
I wanted to make an easy way to access recipes that I use a lot without having to have my cellphone (where I already have a recipe book with all the recipes I've liked) out in the counter while cooking. The first thing I did was print the recipes and put them in a binder like book but it was just too burdensome and intrusive so I just continued to use my phone.
I hadn't even considered cards until just recently when I saw it in a youtube video (even though there's already a recipe box in my house).
This is how I made my own recipe cards.
The tools and materials I used where:
- Box with a lid to put the recipes
- Computer
- Software for making the cards
- Printer paper
- Printer
- Laminator
- Packing paper for decorating the box
- Color paper
- Permanent marker
- Stamps
Most of the material are optional the only thing you really need is a box and cards of the size of the box.
Step 1: Creating the Recipe Cards
The first thing I did was look for cards that were already sold with a template for recipe writing. There were but then I realized that since I already had hundreds of recipes on my phone and it was going to be a pain having to transcribe them to paper. Another issue that I had was the size since some of the recipes I have a pretty long so I would have to write in a small letter which is a little annoying.
So I decided to search for a template online, so I could print them. I settled with Canva and I choose a pretty simple design. I edited to my liking and exported it.
Then I got on Affinity Designer to tweak the design even more and also change the size so it would be appropriate for the box I already owned.
- You could use any software you want or have in hand like Adobe programs, Canva itself or you could probably use microsoft word.
- As you can see I settled on a pretty simplistic design for a couple of reasons. I didn't want to add any images so as to not waste printer ink and I wanted it to be easy to read.
- When accounting for size I also had to take into consideration the fact that I'll laminate the cards so I need them to be a little bit smaller so they'll fit in the box laminated.
Step 2: Organization
The next thing to consider was the categories of my recipes and how many dividers I was going to need to make.
I spent some time in a notepad organizing my recipes until I found my categories. I assigned color to each one of them so I could make each card according to its category.
I also spent some time arranging the recipes in the document so it would be optimal use of space and I wouldn't have to waste that much paper. I ended up with a configuration of 3 recipes in normal size and a little much smaller one that I would use for really simple recipes.
Step 3: Making the Dividers
Knowing how many categories I now could make the dividers.
I could have also made them in the computer and printed them but since there were not that many I made them by hand.
- I grabbed some color paper sheets that were the same as the colors I choose for my categories.
- I measured (taking into account the laminating) the size they would have to be and cut them. Mine ended up being 14.8cm by 9.6cm.
- I took care of letting a piece of paper on top for the tab where the name of the category was.
- Then I decorated the paper with stamps related to cooking.
- I drew straight horizontal lines every 0.5cm to have a place to write the recipes that each category contains.
- I laminated them*
*I laminated the cards before I wrote anything in them since I knew I would make mistakes and maybe some day I would want to add a recipe or even remove one and I didn't want to be blocked form doing so.
I used a permanent marker to write form outside the laminate and if I want I can easily erase it using isopropyl alcohol.
Step 4: Printing the Recipes
Once I had my recipe cards designed I started the migration process from my recipes document to the recipe cards template.
- Be sure to adapt the cards to the size paper you are using to print. I'm using letter size.
Since I decided to laminate the recipe cards I printed them in printer paper.
- If you don't want to laminate then it's better to print in a thicker paper like cardstock.
After printing I cut them to size and started the laminating process.
Step 5: Decorate Your Box
Since the box I'm using is branded I'm going to cover it using packing paper and a water and glue mixture. Depending of the surface of your box it's a good idea to sand the surface of it.
- First I cut strips of the packing paper to size.
- Create a mix of water and glue in an approximately 1 to 1 ratio.
- Dip the strips in the mixture and apply it on the desired surface. In however many layers you want.
- Let dry and decorate however you please.
