Introduction: Making My Plant Scream at Me When It Needs Watering.
Using some sensors, I took the real-time readings from the plant to trigger a sound file through SonicPi.
Real-time readings from the sensors are received and compared to check whether they are below the critical levels, and if yes, the Arduino sends out a MIDI note: an F# note for sub-critical levels (when the plant needs watering) and a Bb note when the moisture level rises abruptly ( when the plant is watered).
The MIDI note then goes through a virtual port and a serial bridge.
SonicPi listens to the incoming note on the virtual port and compares whether the incoming note is F# or Bb.
If the former, it triggers a sound file, and if the latter, another sound file.
All in all, the plant is putting up a musical performance of just two notes.
  1. Moisture sensor.
  2. Humidity sensor (optional).
  3. Arduino Uno.
  4. Bluetooth Speaker.
  5. Breadboard.
  6. LoopMidi.
  7. HairlessMidi serial bridge.
  8. SonicPi.
Step 1: Connect the Sensors
The connection is rather simple and could be done in a jiffy.
Step 2: Write the Arduino Code
int sensor_pin = A0;
int output_value_new ;
int output_value_old = 0;
int satisfied_note = 0x6A;
int scream_note = 0x66;
int threshold_moisture = 80;
void setup() {
  Serial.begin(9600);
  Serial.println("Reading From the Sensor ...");
  delay(2000);
void loop() {
  output_value_new= analogRead(sensor_pin);
  output_value_new = map(output_value_new,550,0,0,100);
  if (output_value_old ==0){
  output_value_old = output_value_new;
  if (output_value_new <= threshold_moisture) {
   //Note on channel 1 (0x90), some note value (note), silent velocity (0x00):
   noteOn(0x90, scream_note, 0x7F);
   delay(100);
  int output_difference = output_value_new - output_value_old;
  if (output_difference >=30){
  //Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
  noteOn(0x90, satisfied_note, 0x7F);
  delay(100);
  Serial.print("Mositure : ");
  Serial.print(output_value_new);
  Serial.println("%");
  delay(1000);
void noteOn(int cmd, int pitch, int velocity) {
 Serial.write(cmd);
 Serial.write(pitch);
 Serial.write(velocity);
Step 3: Write the SonicPi Sketch
screams = "YOUR_SMAPLE_FOLDER_HERE"
satisfied = "YOUR_SMAPLE_FOLDER_HERE"
live_loop :midi_piano do
 use_real_time
 note, velocity = sync "/midi:loopmidi_port_0:1/note_on"
 if note == 102 #Fsharp7
  sample screams, rrand_i(1,7)
  sleep(rrand_i(1,5))
 end
 if note == 106 #Bb7
  sample satisfied, rrand_i(1,3)
  sleep(rrand_i(1,4))
 end
end
in_thread do
 use_real_time
 use_real_time
 if note == 106 #Fsharp7
  sleep(rrand_i(2,6))
 end
 if note == 102 #Bb7
  sleep(rrand_i(1,4))
 end
end
Step 4: The Final Project
I have made the demonstration video along the lines of those sleazy TV infomercial ads we used to see in the days of yore.
