Introduction: Making PCB With Heat Toner Transfer Paper and Laminator.
There are many ways to make PCB.
My favorite method is with Heat Toner Transfer Paper and Laminator.
Step 1:
Cut the copper board and clean the surface.
Step 2:
Print PCB pattern on paper with draft mode.
Put the Heat Toner Transfer Paper on printed draft image and taped.
Then print PCB pattern again with high quality mode.
Step 3:
Cut printed Heat Toner Transfer Paper and put on the copper board and taped.
Put the copper board and Heat Toner Transfer Paper into the laminator about 10 times.
Step 4:
Put off the Heat Toner Transfer Paper.
Check the pin holes and dot on them with marker.
Step 5:
Etched.
Step 6:
Cut and separate each boards.
