Introduction: Making PVC Joints for Pvc Projects
Sometimes when we are making some pvc pipe related projects we need special joints of pvc to completer certain point of project ,those joints are somehow very difficult to get in market when running out of time to complete the project also they are really costly so making these joints with simple available joints such as t joint and u joints can turn into any joint we want as per our need.
if you like this instructable please vote for this project and if you don't understand something please watch the video.
note: this is for only pvc pipe projects not for plumbing so please don't come complain :)
PVC T joint
PVC U joint
PVC cap
Screws or bolts
Step 1: 3 Way Side Corner Joint
This is joint which is a mixture of u joint and t joint normally use for corners can be use in making box type projects.
Place the PVC cap over the U joint the sideway of it and drill a hole from the cap to u joint then place the screw with washer in it now it is same exact joint on the right side can be use in lot of projects.
Step 2: Cross Joint
This is a cross joint which can be connected to 4 sides at once ,take T joint and place a cap over the top and drill a hole, tighten the screw over it.
Step 3: 5 Way Joint
Take the cross joint we made and place the pvc cap on top of that part drill a hole and place the screw in between them making a 5 way pvc joint this can be turned into 6 way as well placing the pvc cap on the opposite side as well.
