Introduction: Making a Cheap WiFi Thermometer With ESP-01S and AHT21B
This is a DIY IoT Temperature Sensor which connects directly to your home Wi-Fi and sends data to Home Assistant via MQTT. I made this because I needed a cheap WiFi thermometer and I didn't like the options available on the market.
YouTube video here: https://www.youtube.com/watch?v=1Bsn6xnnoIs
ESP-01S
FTDI USB to UART 3.3V Cable
Jumper Wires/Hookup Wires
AHT21 Temperature (and Humidity) Sensor
5v to 3.3v Regulator
USB Power Cable
Step 1: Preparing the IDE for Programming
To program the module you will need to install the Arduino IDE on your machine, and add the ESP8266 library.
In the Settings menu, make sure you add the following link to the "Additional boards manager URLs:" field
Then, in the boards manager type "esp8266" and install the package.
After that, activate the Generic ESP8266 Module in the Board menu under the esp8266 sub-menu.
Now you should see new Example sketches in the File menu.
From the Tools menu, select the right serial port under Port for your FTDI UART cable.
You will also need to install this Library: https://github.com/enjoyneering/AHTxx
You can download the code as a Zip file and then Import this as a Library into Arduino under Sketch > Include Library > Add .ZIP Library...
Step 2: Wiring It All Up
Connect everything together as shown. When you want to program the device, you need to jump IO0 to GND (shown in the white wire) before powering on the ESP. When you want to run the application you just programmed, you remove this jumper and then start the ESP by applying power.
Step 3: Programming the Code
The Arduino code is attached below. You will need to update all of the credentials, and also make sure you have an MQTT server running on your home assistant.
If you want to use the deep-sleep mode between measurement updates to enable battery-powered operation, you need to solder the shown pin to RST GPIO on the ESP-01S board. With a 5 minute measurement update interval, the average power consumption is around 5mW which should last a long time on an 18650 battery (around 3 months). If you want longer battery life, just increase the interval.
