Introduction: Making a Chess Board
It is a way of playing chess with different colors and different dimension .
you need:
The Board Supplies
  • red squares 32, 2x 19.05cm, 4x 38.10cm, 6x 57.14cm, 8x 76.19cm, 6x 95.24cm, 4x 114.29cm, 2x 133.33cm,
  • black squares 32, 2x 19.05cm, 4x 38.10cm, 6x 57.14cm, 8x 76.19cm, 6x 95.24cm, 4x 114.29cm, 2x 133.33cm,
The Chess Pieces
  • Eight Pawns: tube 16.33cmx14.96cm (hight 2.86cm), torus 20.41cmx18,70cm (hight 4.71cm), ring 18.78cmx17.06cm (hight 0.95cm), cone1 17.14cmx15,71cm (hight 19,05cm), cone2 8.98cmx8.23 (hight 26,67cm), sphere1 13.82cmx12.61cm (hight 4.76cm), sphere2 10.61cmx9.73cm (hight 11.43cm),
  • Two Bishops: tube 16.33cmx14.96cm (hight 2.86cm), torus 20.41cmx18,70cm (hight 4.71cm), ring 17.01cmx15.59cm (hight 1.54cm), cone1 15.31cmx14,03cm (hight 18.67cm), cone2 8.02cmx7.35 (hight 26.13cm), sphere1 10.21cmx 9.35cm (hight 3.07cm), sphere2 8.50cmx 7.79cm (hight 3.07cm), Pacman 8.50cmx 7.79cm (hight 10.76cm), sphere3 1.70cmx 1.56cm (hight 1.54cm)
  • Two Knights:
  • Two Rooks: torus1 20.41cmx18,70cm (hight 4.71cm), tube 16.33cmx14.96cm (hight 2.86cm), ring 17.14cmx15.71cm (hight 0.97cm), cone 15.51cmx14,22cm (hight 30.25cm), torus2 13.88cmx12.72cm (hight 2.90cm), torus3 17.14cmx15.65cm (hight 2.25cm), Runde Arorndnu... 17.14cmx15.44cm (hight 2.90cm)
  • One Queen: tube20.41cmx18,70cm (hight 4.71cm), tube 16.33cmx14.96cm (hight 2.86cm), ring 17.14cmx15.71cm (hight 0.97cm), cone1 11.96cmx11.36cm (hight 18.21cm), cone2 11.90cmx11.29cm (hight 18.21cm), sphere1 19.00cmx 18.04cm (hight 4.75cm), sphere2 16.19cmx 14.70cm (hight 5.54cm), ring 14.78cmx13.23cm (hight 1.58cm), cone metric gear 19.00cmx 17.37cm (hight 11.08cm), sphere 5.16cmx4.73cm (hight 6.00cm),
  • One King: tube17.23x15.80cm (hight 2.42cm), tube 20.41cmx18,70cm (hight 4.71cm), ring 17.14cmx15.71cm (hight 0.97cm), cone1 11.96cmx11.36cm (hight 18.21cm), cone2 11.90cmx11.29cm (hight 18.21cm), sphere1 19.00cmx 18.04cm (hight 4.75cm), sphere2 16.19cmx 14.70cm (hight 5.54cm), ring 17.14cmx15.71cm (hight 0.97cm), cone3 11.90cmx11.29cm (hight 18.21cm), half shape 16.19cmx 14.70cm (hight 5.54cm), sphere3 16.19cmx 14.70cm (hight 5.54cm), sunflower 16.19cmx 14.70cm (hight 5.54cm),
Step 1: Making the Board
To start you need to now how many squares you needs to make the board. First you need 64 squares next to each other. The squares need to be 20cm bay 20cm and in all rows there should be 8 squares.
Step 2: Color Coding the Board
After putting them tougher, you should color coded in tow different colors. I shows red and black, you could shows white and black or any other color you like.
Step 3: Making It to in Interesting Board
The next step it is to make in a new dimension, to make it more interesting. There for you chang the hight propotion of all the squares. The red squares size adjustment are 32, 2x 19.05cm, 4x 38.10cm, 6x 57.14cm, 8x 76.19cm, 6x 95.24cm, 4x 114.29cm, 2x 133.33cm, and the size adjustment for the black squares are 32, 2x 19.05cm, 4x 38.10cm, 6x 57.14cm, 8x 76.19cm, 6x 95.24cm, 4x 114.29cm, 2x 133.33cm.
Step 4: Making the Chess Pieces
Every chess pieces has his on shapes and settings for the building proses. The first step is always the same. tube 16.33cmx14.96cm (hight 2.86cm), torus 20.41cmx18,70cm (hight 4.71cm), ring 18.78cmx17.06cm (hight 0.95cm). in this order you starting the lower part of all the pieces. In the Supplies you can all the shapes you net and there size in the right order.
Step 5: Color Coding the Chess Pieces
You can choose which colors you want to use for the chess pieces like me, but make sure that the pieces fit exactly into the fields and are 46cm tall.
Step 6: Name Each Row on the Board
In a normal chess board, each row has a specific number from 1-8 and a specific letter from A-H. you can add these rows with the text tool and make sure that the letters are behind the chess pieces.
