Introduction: Making a Folding Table in Fusion
In this instructable I'll showcase how you can design a simple wall mounted folding table using standard building materials.
Fusion 360
Step 1: Making a Reference Wall
First let's make a reference wall so we'll have some context when we're designing the table.
To do this I used 8ft 2x4 studs and added half inch drywall on top.
Step 2: Wall Mount
Next let's add a wall mount for the table. This will determine the height of the table, in my case I placed it a couple feet up. This is simply a piece of half-inch plywood we'll be screwing the hardware on to.
Step 3: Table Top
Now we'll make the table top with a sheet of half-inch plywood.
Step 4: Hinges
Now lets make it flex! to find hinges I went to the insert menu, and selected insert McMaster-Carr component. then searched through until I found a hinge I liked.
Once I placed the Carr STEP file I added another one on the other side of the table top.
Step 5: Reinforcement
Then I added a couple 2x4's to reinforce the table top.
Step 6: Legs
Then with another pair of hinges and 2x4's I added legs! I set the length to correspond with the height of the table from step 2.
Step 7: Table Finished
That's it for the table!
Step 8: Secure It
Before we leave let's add a 3d printable snap fit for the table so it doesn't swing down when not in use.
Step 9: Done!
Here you can see the table in both it's folded and unfolded positions, as well as some example benches for when it's in use!
