Introduction: Making a Garden Bench From an Old Worktop
I don’t have an extensive array of power tools so this will mostly be hand tools, but if I have a power tool that will work I won’t be shy!
I also have some pieces of teak, and some reclaimed pine floor boards which I will use for the legs and supports.
Reclaimed oak worktop
Reclaimed pine floorboards totalling about 2 metres long
Teak, 2cm by 5 cm by 200 cm
Step 1: Marking Up and Cutting the Leg Tenons
First of all, we needed to cut the legs to length. We are tall in my family so we deliberately cut the legs long. We spent a certain amount of time sitting on things of different heights before we decided the height we wanted the bench at. Subtract the thickness of the top and add a bit for the tenons and then you have the length of the legs. Cut them to length with your method of choice. I only have hand tools so that was my friendly cross cut saw.
Loads of tutorials online on how to cut tenons so I will not do that here but I always cut the tenons before the mortices (I don't think this is as controversial as with dovetails). I have a marking gauge with two pins, which I believe is called a mortice gauge. Marking up tenons that are all the same size means I can leave the pins set and they are the right size when I come to mark the mortices.
I of course didn't do this and cut the first tenon lengthwise along the leg (see the picture of chopping the mortice later to see what I mean). Looking at it after I cut it, I was concerned this wouldn't be strong enough so cut the remaining tenons so they were more square. I then left the mortice gauge set to this so I only needed to reset it once.
Definitely don't do what I do!
Step 2: Shaping the Bench
So next thing was to sort out the reclaimed worktop.
I decided to sand it back as I didn't know what finish was on there now and if I got back to raw wood I'd know what I needed to do to look after it.
I cheated here as I have a random orbital sander and it really didn't take long. Wasn't looking for a really fine finish so I think I only went to something like 120. It's for a bench that will live outside so it just needed not to snag.
Next was the painful bit. I wanted to shape the ends to it didn't look like someone had just dumped a worktop on some legs, even though I was just dumping a worktop on some legs. I didn't have the power tools to do this with so I ended up using a combination of hand saw and a big gouge to shape it. It was a pain and if you can find someone with a power tool for this part of the job, I'd recommend it.
I ended up reshaping this a few times as I didn't like the first attempts I made and there was a lot of refinement.
Once the shape was ok, I rounded over the top using a spokeshave just to make sure there were no sharp edges to dig in to legs.
Step 3: Completing the Legs
So having shaped the top I can now finish the frame for the legs. This just involves putting in stretchers to create the base the bench will sit on.
I did this first as it just makes it easier to manage the pieces and then make sure I cut the mortices in the top in the right place if I make the frame first. Then I can use the frame itself for the markup and not rely on trying to make really accurate measurements.
So I used some old floor boards we had removed from our house for the long stretchers and some pallet wood for the short stretchers. I used through tenons for the long stretchers Same as a normal mortise and tenon except the mortise goes all the way through the leg.
I then used a wedged dowel to pin the tenon through the other side of the leg and glued it all together.
Step 4: Fitting the Legs
So now the frame for the legs is complete I can use that to mark out the mortices for the framework.
With the top upside down on the workmate, I can put the legs on the top and mark out the position for the mortices. Then it's simply chop them out with a chisel in the normal way. I also have a cheap router plane which is a bit of a pain to set the depth on but is very useful. I used this to flatten the bottom of the mortise.
Having fit the legs, I decided the frame could do with some additional support just to help resist some of the lateral forces. This honestly had nothing to do with my shoddy joinery and a lack of confidence in my mortise work. Honest.
So I don't know what they are officially called, but I decided to put some angled supports on a couple of the joints to spread the pressure. I used some offcuts of teak to make these. I had some vaguely square pieces so I marked a diagonal as a start and then drew a slightly more attractive curved shape and cut it out with a coping saw. These were then glued into place and clamped.
It's worth pointing out the clamping was something of a challenge. Creative use of masking tape solved this and I would heartily recommend you explore the uses of masking tape as a clamp.
Once the glue dried, I used a combination of spokeshave and gouges to soften the sharp edges and put what I considered attractive chamfers on the stretchers and support pieces. I kept the legs square other than the bottoms of the legs. The feet should be chamfered as if they aren't, when the bench is moved there is a risk of them feet catching and causing splits in the legs.
Step 5: And I'm Done
So as I said, my wife is definitely in charge and once I had the bench on its feet, she was happy with the the large, coffee table like look of the bench and found it comfortable not to have a back so she vetoed it.
It means the look of the bench is not quite what I intended as I would have made it a little narrower as I left it that wide to enable me to put a back on it but c'est la vie.
Hope this has been useful.
