Introduction: Making a Homemade RFID Punch Clock
In this Instructable I'll show you how to build a homemade punch clock working with RFID cards.
This is a non-rigurous English translation for an article in my personal website: https://jjosemayorga.com/creando-una-maquina-de-fichar/.
You can find this and many other interesting projects in my website and my social media.
🌐 https://jjosemayorga.com/
Twitter ► https://twitter.com/jjosemayorga
Instagram ► https://www.instagram.com/jjosemayorga/
Facebook ► https://www.facebook.com/jjosemayorgau
Youtube ► https://www.youtube.com/@jjosemayorga
TikTok ► https://www.tiktok.com/@jjosemayorga
Step 1: Wire the Components All Together
In order to make the whole setup work, you just need to wire all the components in the way I show you in this picture.
If you need further explanation on how each element works or why I use them that way, you just need to visit the article on my website and get some instruction on it (it's in Spanish but, if you are not fluent in that language, Google translator will do the job 😉).
Step 2: Load the Arduino Code
As for the Arduino part, I provide you the Arduino code I've used.
It's a pretty simple of the use of serial communication. Should you need to learn the very basics of this, let me address you again to the article on my website.
Step 3: Build the Java App
Here you will find the Java code.
package fichajes;
import java.io.BufferedReader;
import java.io.BufferedWriter;
import java.io.File;
import java.io.FileReader;
import java.io.FileWriter;
import java.io.IOException;
import java.io.InputStreamReader;
import java.io.OutputStream;
import java.io.Writer;
import java.util.Enumeration;
import java.util.Objects;
import java.util.Timer;
import java.util.TimerTask;
import java.util.Date;
import java.text.*;
import java.awt.event.*;
import java.awt.*;
import javafx.embed.swing.JFXPanel;
import javafx.stage.FileChooser;
import javax.swing.*;
import java.io.*;
import javax.imageio.*;
import com.sun.glass.ui.Platform;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import gnu.io.SerialPortEvent;
import gnu.io.SerialPortEventListener;
public class MaquinaFichar extends JFrame implements SerialPortEventListener
int segundos;//manejar el valor del contador
boolean frozen; //manejar el estado del contador
Timer timer = new Timer();
Date date = new Date();
SimpleDateFormat ft=new SimpleDateFormat("dd/MM/yyyy HH:mm:ss");
JFrame marco=new JFrame("Aplicación de control de fichajes");
JLabel titulo=new JLabel();
JLabel hora=new JLabel();
JLabel onoff=new JLabel();
JButton encender=new JButton();
JLabel inicioregistro=new JLabel("Inicio de registro mostrado");
JTextField tf_inicioregistro=new JTextField(20);
JLabel finregistro=new JLabel("Fin de registro mostrado");
JTextField tf_finregistro=new JTextField(20);
JButton btn_guardar=new JButton();
JButton btn_abrir=new JButton();
int encendido=0;
int conectado=1;
JPanel pnl_encendido=new JPanel();
JLabel lbl_puerto=new JLabel("Puerto de conexión:");
String[] str_puerto={"COM1","COM2","COM3","COM4","COM5","COM6","COM7","COM8","COM9","COM10","COM11","COM12","COM13","COM14","COM15","COM16","COM17","COM18","COM19","COM20","COM21","COM22","COM23","COM24","COM25","COM26"};
JComboBox cmb_puerto=new JComboBox(str_puerto);
JLabel lbl_baudrate=new JLabel("Baud Rate:");
String[] str_baudrate={"4800","9600","19200","38400","57600","115200","234000","460800","921600","1382400"};
JComboBox cmb_baudrate=new JComboBox(str_baudrate);
JTextField txt_noticias=new JTextField(40);
JPanel pnl_puerto=new JPanel();
JPanel pnl_baudrate=new JPanel();
final JFXPanel fxPanel = new JFXPanel();
File selectedFile=null;
File savedFile=null;
String nombrearchivo=null;
String infile=null;
JTextArea texto=new JTextArea();
JScrollPane scroll=new JScrollPane(texto);
String personal[][]=new String[2][2];
/** The output stream to the port */
private OutputStream output = null;
private BufferedReader input;
SerialPort serialPort;
private String PORT_NAME = "COM1";
/** Milliseconds to block while waiting for port open */
private static final int TIME_OUT = 2000;
/** Default bits per second for COM port. */
private static int DATA_RATE = 9600;
MaquinaFichar()
try
marco.setContentPane(new JLabel(new ImageIcon(ImageIO.read(new File("fondo.png")))));
catch(IOException e)
e.printStackTrace();
personal[0][0]="25 9A 0F 11";
personal[1][0]="81 EE 3C D9";
personal[0][1]="out";
personal[1][1]="out";
timer.schedule(new MiTarea(), 0, 1000);
marco.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
marco.setIconImage(Toolkit.getDefaultToolkit().createImage("maquinafichar.png"));
marco.setResizable(false);
GridBagLayout gridbag=new GridBagLayout();
GridBagConstraints gbc=new GridBagConstraints();
marco.setLayout(gridbag);
gbc.insets=new Insets(10,10,10,10);
gbc.gridx=0;
gbc.gridy=0;
gbc.gridwidth=6;
gbc.gridheight=1;
gbc.weightx=1;
gbc.weighty=1;
titulo.setFont(new Font("Arial", Font.PLAIN, 60));
titulo.setText("REGISTRO DE FICHAJES");
marco.add(titulo,gbc);
gbc.gridx=0;
gbc.gridy=1;
gbc.gridwidth=4;
gbc.gridheight=1;
gbc.weightx=1;
gbc.weighty=1;
hora.setFont(new Font("Arial", Font.PLAIN, 48));
hora.setText(ft.format(date));
hora.setOpaque(true);
hora.setBackground(Color.cyan);
marco.add(hora,gbc);
/*gbc.gridx=4;
gbc.gridy=1;
gbc.gridwidth=1;
gbc.gridheight=1;
gbc.weightx=1;
gbc.weighty=1;
gbc.anchor=GridBagConstraints.EAST;*/
//encender.setPreferredSize(new Dimension(100, 100));
encender.setIcon(new ImageIcon("redbutton.png"));
encender.setName("encender");
encender.setToolTipText("Encender/Apagar");
encender.setBorderPainted(false);
encender.setContentAreaFilled(false);
encender.setFocusPainted(false);
encender.setCursor(new Cursor(Cursor.HAND_CURSOR));
//encender.setOpaque(false);
encender.addMouseListener(new Seleccion());
pnl_encendido.add(encender,gbc);
/*gbc.gridx=5;
gbc.gridy=1;
gbc.gridwidth=1;
gbc.gridheight=1;
gbc.weightx=1;
gbc.weighty=1;
gbc.anchor=GridBagConstraints.WEST;*/
//onoff.setText("<html><font size=20 color=red>OFF</font></html>");
//encender.setPreferredSize(new Dimension(200, 100));
onoff.setText("OFF");
onoff.setFont(new Font("Arial", Font.PLAIN, 100));
onoff.setForeground(Color.red);
pnl_encendido.add(onoff,gbc);
gbc.gridx=4;
gbc.gridy=1;
gbc.gridwidth=2;
gbc.gridheight=1;
gbc.weightx=1;
gbc.weighty=1;
pnl_encendido.setOpaque(false);
marco.add(pnl_encendido,gbc);
gbc.gridx=0;
gbc.gridy=2;
gbc.gridwidth=4;
gbc.gridheight=5;
texto.setEditable(false);
scroll.setPreferredSize(new Dimension(600, 400));
marco.add(scroll,gbc);
gbc.insets=new Insets(0,0,0,0);
gbc.gridx=4;
gbc.gridy=2;
gbc.gridwidth=2;
gbc.gridheight=1;
gbc.anchor=GridBagConstraints.SOUTHWEST;
inicioregistro.setFont(new Font("Arial", Font.PLAIN, 32));
marco.add(inicioregistro,gbc);
gbc.gridx=4;
gbc.gridy=3;
gbc.gridwidth=2;
gbc.gridheight=1;
tf_inicioregistro.setEditable(false);
tf_inicioregistro.setFont(new Font("Arial", Font.PLAIN, 32));
tf_inicioregistro.setBackground(Color.white);
//tf_inicioregistro.setText("hola");
gbc.anchor=GridBagConstraints.NORTHWEST;
marco.add(tf_inicioregistro,gbc);
gbc.gridx=4;
gbc.gridy=4;
gbc.gridwidth=2;
gbc.gridheight=1;
finregistro.setFont(new Font("Arial", Font.PLAIN, 32));
marco.add(finregistro,gbc);
gbc.gridx=4;
gbc.gridy=5;
gbc.gridwidth=2;
gbc.gridheight=1;
tf_finregistro.setEditable(false);
tf_finregistro.setFont(new Font("Arial", Font.PLAIN, 32));
tf_finregistro.setBackground(Color.white);
marco.add(tf_finregistro,gbc);
gbc.gridx=4;
gbc.gridy=6;
gbc.gridwidth=1;
gbc.gridheight=1;
gbc.anchor=GridBagConstraints.CENTER;
btn_guardar.setFont(new Font("Arial", Font.PLAIN, 18));
btn_guardar.setText("Guardar");
btn_guardar.setIcon(new ImageIcon("guardar.png"));
btn_guardar.setName("guardar");
btn_guardar.addMouseListener(new Seleccion2());
btn_guardar.setToolTipText("No hay registro para guardar");
btn_guardar.setEnabled(false);
marco.add(btn_guardar,gbc);
gbc.gridx=5;
gbc.gridy=6;
gbc.gridwidth=1;
gbc.gridheight=1;
btn_abrir.setFont(new Font("Arial", Font.PLAIN, 18));
btn_abrir.setText("Abrir");
btn_abrir.setIcon(new ImageIcon("abrir.png"));
btn_abrir.setName("abrir");
btn_abrir.addMouseListener(new Seleccion2());
marco.add(btn_abrir,gbc);
//gbc.insets=new Insets(5,5,5,5);
gbc.gridx=0;
gbc.gridy=7;
gbc.gridwidth=4;
gbc.gridheight=1;
//gbc.fill=GridBagConstraints.HORIZONTAL;
txt_noticias.setEditable(false);
txt_noticias.setBackground(Color.white);
marco.add(txt_noticias,gbc);
gbc.gridx=4;
gbc.gridy=7;
gbc.gridwidth=1;
gbc.gridheight=1;
gbc.weightx=1;
//gbc.fill=GridBagConstraints.NONE;
pnl_puerto.add(lbl_puerto,gbc);
cmb_puerto.addItemListener(new PORTlistener());
pnl_puerto.add(cmb_puerto,gbc);
pnl_puerto.setOpaque(false);
marco.add(pnl_puerto,gbc);
gbc.gridx=5;
gbc.gridy=7;
gbc.gridwidth=1;
gbc.gridheight=1;
gbc.weightx=1;
pnl_baudrate.add(lbl_baudrate,gbc);
cmb_baudrate.addItemListener(new BRlistener());
pnl_baudrate.add(cmb_baudrate,gbc);
pnl_baudrate.setOpaque(false);
marco.add(pnl_baudrate,gbc);
marco.pack();
marco.setVisible(true);
marco.setLocationRelativeTo(null);
class Seleccion extends MouseAdapter
public void mousePressed(MouseEvent e)
Component aux=e.getComponent();
public void mouseReleased(MouseEvent e)
if(aux.getName().equals("encender")&&encendido==1)
encendido=0;
conectado=0;
serialPort.removeEventListener();
serialPort.close();
txt_noticias.setText("Conexión interrumpida");
tf_finregistro.setText(hora.getText());
btn_abrir.setToolTipText("Abrir registro previo");
btn_abrir.setEnabled(true);
btn_guardar.setToolTipText("Guardar registro");
btn_guardar.setEnabled(true);
else if(aux.getName().equals("encender")&&encendido==0)
initialize();
if(conectado==1)
encender.setIcon(new ImageIcon("greenbutton.png"));
onoff.setText("ON");
onoff.setForeground(Color.green);
encendido=1;
tf_inicioregistro.setText(hora.getText());
tf_finregistro.setText("En ejecución...");
btn_abrir.setToolTipText("Para abrir un registro debe apagar la lectura de tarjetas");
btn_abrir.setEnabled(false);
btn_guardar.setToolTipText("Para guardar un registro debe apagar la lectura de tarjetas");
class Seleccion2 extends MouseAdapter
if(aux.getName().equals("abrir"))
FileChooser fileChooser = new FileChooser();
selectedFile = fileChooser.showOpenDialog(null);
if (selectedFile != null) {
txt_noticias.setText("Fichero Seleccionado: " + selectedFile.getName());
nombrearchivo=selectedFile.getAbsolutePath();
Leer(nombrearchivo);
//System.out.println(nombrearchivo);
else {
txt_noticias.setText("Cancelada selección de fichero");
if(aux.getName().equals("guardar"))
savedFile = fileChooser.showSaveDialog(null);
if (savedFile != null)
infile=savedFile.getAbsolutePath();
Crear(infile);
txt_noticias.setText("Guardado como: " + savedFile.getName());
else {
txt_noticias.setText("Cancelado guerdado de fichero");
class BRlistener implements ItemListener
@Override
public void itemStateChanged(ItemEvent evt)
// TODO Auto-generated method stub
JComboBox cb = (JComboBox) evt.getSource();
String str_DATA_RATE = (String) cb.getSelectedItem();
DATA_RATE=Integer.parseInt(str_DATA_RATE);
txt_noticias.setText("BaudRate cambiado a: "+str_DATA_RATE);
class PORTlistener implements ItemListener
@Override
String str_PORT_NAME = (String) cb.getSelectedItem();
PORT_NAME=str_PORT_NAME;
txt_noticias.setText("Puerto cambiado a: "+str_PORT_NAME);
class MiTarea extends TimerTask
public void run()
}// end run()
public void initialize()
CommPortIdentifier portId = null;
Enumeration portEnum = CommPortIdentifier.getPortIdentifiers();
// iterate through, looking for the port
while (portEnum.hasMoreElements())
CommPortIdentifier currPortId = (CommPortIdentifier)
portEnum.nextElement();
if (PORT_NAME.equals(currPortId.getName()))
portId = currPortId;
break;
if (portId == null)
System.out.println("Could not find COM port.");
txt_noticias.setText("Conexión fallida");
encendido=0;
conectado=0;
return;
else
conectado=1;
try
// open serial port, and use class name for the appName.
serialPort = (SerialPort) portId.open(this.getClass().getName(),
TIME_OUT);
// set port parameters
serialPort.setSerialPortParams(DATA_RATE,
SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
// open the streams
input = new BufferedReader(new InputStreamReader(serialPort.getInputStream()));
output = serialPort.getOutputStream();
// add event listeners
serialPort.addEventListener(this);
serialPort.notifyOnDataAvailable(true);
//lbl_conectar.setIcon(new ImageIcon("lightON.png"));
txt_noticias.setText("Conexión establecida");
catch (Exception e)
System.err.println(e.toString());
* Handle an event on the serial port. Read the data and print it.
public synchronized void serialEvent(SerialPortEvent oEvent)
if (oEvent.getEventType() == SerialPortEvent.DATA_AVAILABLE)
try
String inputLine=input.readLine();
//if(inputLine.trim().equals("25 9A 0F 11"))
//txt_noticias.setText("wololo");
//texto.append("Entrada: " + inputLine + "; " + hora.getText() + "\n");
for(int i=0;i<2;i++)
//texto.append(Integer.toString(i));
//texto.append(inputLine);
if(Objects.equals(personal[i][0],inputLine.trim()) && personal[i][1].equals("out"))
personal[i][1]="in";
texto.append("Entrada: " + inputLine + "; " + hora.getText() + "\r\n");
else if(Objects.equals(personal[i][0],inputLine.trim()) && personal[i][1].equals("in"))
personal[i][1]="out";
texto.append("Salida: " + inputLine + "; " + hora.getText() + "\r\n");
} catch (Exception e) {
public void Leer(String archivosalida)
try
FileReader fr=new FileReader(nombrearchivo);
BufferedReader textReader=new BufferedReader(fr);
int numberOfLines=readLines();
String[] textData=new String[numberOfLines];
int i;
for(i=0; i<numberOfLines;i++)
textData[i]=textReader.readLine();
System.out.println(textData[i]);
//texto.append(textData[i]+"\r\n");
if(textData[0].indexOf(':')>-1&&textData[1].indexOf(':')>-1)
if(numberOfLines>1 && Objects.equals(textData[0].substring(0, textData[0].indexOf(':')),"Inicio de registro mostrado") && Objects.equals(textData[1].substring(0, textData[1].indexOf(':')),"Fin de registro mostrado") )
tf_inicioregistro.setText(textData[0].substring(textData[0].indexOf(":")+1));
tf_finregistro.setText(textData[1].substring(textData[1].indexOf(":")+1));
for(i=2; i<numberOfLines;i++)
txt_noticias.setText("Registro leído correctamente");
else
txt_noticias.setText("Formato de archivo incorrecto");
else
textReader.close();
int readLines() throws IOException
FileReader file_to_read=new FileReader(nombrearchivo);
BufferedReader bf=new BufferedReader(file_to_read);
String aLine;
int numberOfLines=0;
while((aLine=bf.readLine())!=null)
numberOfLines++;
bf.close();
return numberOfLines;
public void Crear(String archivoentrada)
try
Writer output = null;
File file = new File(archivoentrada);
output = new BufferedWriter(new FileWriter(file,true));
output.append("Inicio de registro mostrado: " + tf_inicioregistro.getText() + "\r\n");
output.append("Fin de registro mostrado: " + tf_finregistro.getText() + "\r\n");
output.append(texto.getText());
output.close();
public static void main(String[] args)
MaquinaFichar app=new MaquinaFichar();
In order to implement a modern file chooser/opener, I created the following class:
package fichajes;
import javafx.application.Application;
import javafx.stage.Stage;
import javafx.stage.FileChooser.ExtensionFilter;
import javafx.scene.Scene;
import javafx.scene.layout.VBox;
import javafx.scene.layout.HBox;
import javafx.scene.text.Font;
import javafx.scene.text.FontWeight;
import javafx.scene.text.Text;
import javafx.scene.paint.Color;
import javafx.scene.control.Label;
import javafx.scene.control.Button;
import javafx.geometry.Pos;
import javafx.geometry.Insets;
import javafx.event.ActionEvent;
import javafx.event.EventHandler;
import java.util.List;
public class SelectFileChooserExample
extends Application {
private Text actionStatus;
private Stage savedStage;
private static final String titleTxt = "JavaFX File Chooser Example 1";
/*public static void main(String [] args) {
Application.launch(args);
@Override
public void start(Stage primaryStage) {
primaryStage.setTitle(titleTxt);
// Window label
Label label = new Label("Select File Choosers");
label.setTextFill(Color.DARKBLUE);
label.setFont(Font.font("Calibri", FontWeight.BOLD, 36));
HBox labelHb = new HBox();
labelHb.setAlignment(Pos.CENTER);
labelHb.getChildren().add(label);
// Buttons
Button btn1 = new Button("Choose a file...");
btn1.setOnAction(new SingleFcButtonListener());
HBox buttonHb1 = new HBox(10);
buttonHb1.setAlignment(Pos.CENTER);
buttonHb1.getChildren().addAll(btn1);
Button btn2 = new Button("Choose multiple PDF files...");
btn2.setOnAction(new MultipleFcButtonListener());
HBox buttonHb2 = new HBox(10);
buttonHb2.setAlignment(Pos.CENTER);
buttonHb2.getChildren().addAll(btn2);
// Status message text
actionStatus = new Text();
actionStatus.setFont(Font.font("Calibri", FontWeight.NORMAL, 20));
actionStatus.setFill(Color.FIREBRICK);
// Vbox
VBox vbox = new VBox(30);
vbox.setPadding(new Insets(25, 25, 25, 25));;
vbox.getChildren().addAll(labelHb, buttonHb1, buttonHb2, actionStatus);
// Scene
Scene scene = new Scene(vbox, 500, 300); // w x h
primaryStage.setScene(scene);
primaryStage.show();
savedStage = primaryStage;
private class SingleFcButtonListener implements EventHandler<ActionEvent> {
@Override
public void handle(ActionEvent e) {
showSingleFileChooser();
private void showSingleFileChooser() {
File selectedFile = fileChooser.showOpenDialog(null);
actionStatus.setText("File selected: " + selectedFile.getName());
else {
actionStatus.setText("File selection cancelled.");
private class MultipleFcButtonListener implements EventHandler<ActionEvent> {
@Override
showMultipleFileChooser();
private void showMultipleFileChooser() {
fileChooser.setTitle("Select PDF files");
fileChooser.setInitialDirectory(new File("X:\\testdir\\two"));
fileChooser.getExtensionFilters().addAll(
new ExtensionFilter("PDF Files", "*.pdf"));
List<File> selectedFiles = fileChooser.showOpenMultipleDialog(savedStage);
if (selectedFiles != null) {
actionStatus.setText("PDF Files selected [" + selectedFiles.size() + "]: " +
selectedFiles.get(0).getName() + "..");
else {
actionStatus.setText("PDF file selection cancelled.");
Step 4: Try the Whole Setup
Here you have a demo of the project. Should you have any doubt or difficulty to reach an optimal result, you can contact me.
