Introduction: Creating Our Kite: Traditional Kite
This is a guide on how to make a kite by Anesu, Emalisa, Yanick, Kelvin
Step 1: Materials
" String
" Scotch tape
" One sheet of strong paper
" 2 strong straight wooden sticks
" Scissors
" Knife
" Scotch tape
" Scissors
" Knife
Step 2: Cross Sticks
Make a cross with the 2 sticks, with the shorter stick placed horizontally across the longer stick, about a third from the top. Make sure that both sides of the cross piece are equal width.
Step 3: Tie Sticks Together
Tie the 2 sticks together with the string (reinforce with scotch tape) in such a way as to make sure that they are perpendicular to each other.
Step 4: Making Notches
Cut a notch at both ends of each stick (4 notches in total). Make it deep enough for them deep enough for the string to fit in properly.
Step 5: Wrapping of String
Now wrap a single layer of string all the way around the kite. It should go right into the notches. Start and end at the bottom of the kite. After you have wrapped it and tied it add pieces of tape over the notches so the string doesn't pop out with the force of the wind. Pull the string reasonably tight before tying it. The cross bar should be a little bowed.
Step 6: Frame
Put your frame on the strong paper and cut out the outline of the string with a little extra width. Now fold the extra width over the string and tape it down. Make sure the paper is reasonably flat
Step 7: Adding of the Tail
Tie a long piece of string (about 6ft) to the bottom end of your kite. Put pieces of cloth, about a foot apart, on the 6ft piece of string for added stability.
