Introduction: Making a Powerful Generator From a Blender Motor DIY
Hi!
In this instructable, i will teach you how to transform a 220 volts Blender motor into a powerful generator without any additional circuit.
Blender Motors are actually the universal Motors which are capable of operating at both AC or DC inputs.
High power DC Motors are really difficult to find at home but the Blender motors are easily available almost everywhere and from that point of view, this project is of great importance.
Since they operate at high voltage therefore they also generate high voltage of 200V to 300V.
Full video -->https://www.youtube.com/watch?v=9uwU4rsyrLAYoutube --> www.youtube.com/creativElectron7M
Step 1: Requirements:
- mobile charger/laptop charger
- 48 volts to 220 volts inverter
- bulbs
- 1-Universal motor
- jumper wires
- bulb connectors
- thread
Step 2: Connections:
The above Universal motor has four wires.Two wires both black in colour are for the armature while the other two wires black and red are for the field.
Now take a laptop charger and measure its output voltage with a multimeter. I have used a 19 volts laptop charger though you can use any voltage range from 5 volts which is for a mobile charger to 20 volts which is usually for the laptop chargers.
Connect the two output wires from the laptop charger to the field wires of the universal motor irrespective of the polarity.
Once you do that, the field winding gets activated.Now take an inverter and connect it to the armature terminals of the Universal motor.
To the output 220 volts or 110 volts side of the inverter, connect the load bulb.
Now take the plastic thread and wound it around the shaft of the Blender(universal) motor.
Step 3: Testing:
After your completed the previous steps, all you have to do is hold the Universal motor with one hand and pull the plastic thread as fast as you can with your other hand.
You should see your bulb glowing brightly.
The maximum voltage that i could achieve with the hand generation test was 122.8V DC as can be seen in the picture.
The maximum power that it can generate should be 200W though it depends a lot upon the mechanical rotation and the power fed to the field.
To understand it better please watch the video here.
